Old 02-26-2007   #1
rst95eclipse
Custom Grind Cams
I have a set of custom grind cams manufactured by Comp Cams (who manufactures for FP). They are very similar to FP3x's. The lobes between the 3x's and the custom's have a difference of .1mm or less. I have the measurements for both sets of cams from my caliper. If you're interested, PM me. They are brand new.
$300 takes both. I will not separate them.
Old 03-01-2007   #3
sideways motorsports
Re: Custom Grind Cams
They dont look so brand new in the picture. Please send me manufactures specs to dan_moore@earthlink.net Thanks.
sideways motorsports is offline   Reply With Quote
Old 03-02-2007   #4
rst95eclipse
I assure you that they are brand new. 95talonracer and EclipseGST can vouch for them, since they are the only two, besides myself, that have seen them in person on here. The pictures aren't very good at depicting that. The first pic posted is the best. The stuff on the rag is assembly lube, not oil. I decided to coat the lobes with it so they would not rust and I used the rags so that they wouldn't get damaged in the boxes. I will be sending you the specs shortly. I spoke to Comp Cams to make sure that the specs were correct. The only difference between these and FP3xs is 1 degree of duration and .004 (4 thousands) of lift.
Name:	sell it 018.jpg
ID:	5201   Click image for larger version
Name:	sell it 019.jpg
ID:	5202   Click image for larger version
Name:	sell it 017.jpg
Old 03-03-2007   #5
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Yes I personally seen them and they are brand new. They are a really nice looking set of cams. Good luck with the sale.
Old 04-04-2007   #6
2.SlowES
2.SlowES's Avatar
Send a message via AIM to 2.SlowES
Are these like the 272s? Can they be ran with a stock head?
2.SlowES is offline   Reply With Quote
Old 04-04-2007   #7
Look on FP's site for the FP3x specs. They're quite a bit bigger than 272's.
Old 04-04-2007   #8
2.SlowES
2.SlowES's Avatar
Damn, I'm looking for 272's.
Old 04-05-2007   #9
rst95eclipse
The cams I'm selling...
Adv. Duration: 258
Duration @ .050: 211
Valve lift: .410
Crower 272...
Adv. Duration: 272
Valve lift: .393
Crower 280...
Adv. Duration: 280
Duration @ .050: 213
Valve lift: .411
OEM (Factory)...
Adv. Duration: 256
Duration @ .050: 190
Valve Lift: .366
Old 04-05-2007   #12
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
I also vouch as well that these are brand new. Never been installed what so ever, no scratches or anything wrong.
Buy em up!
Originally Posted by shoutbox
Old 04-05-2007   #13
crazy_skier
A.E.K.Δ.B
crazy_skier's Avatar
Beer Dude 2 Champion!
Drives: 1994 Suburban
so are these the equivelent of a 258 because that is what it looks like. If they are like the 280's or larger how much would you want for those and the new springs/retainers
Old 04-05-2007   #14
95talonracer
Finally Tuned...
Drives: Spyder GSX
Great person and has Quality parts. I seen the valve springs and they are BRAND NEW as well. I would buy this setup if I had not already bought mine already.
Amsoil Dealer
Old 04-06-2007   #15
rst95eclipse
Forced Performance is a bit on the conservative side when commenting on duration. I asked the cam specialist at FP, he stated that Crower "overestimates" (for lack of a better term) their advertised duration.
Cams: $300
Crower Valve Springs: $200
