Old 03-03-2007   #1
Evo2NV
Evo2NV's Avatar
F/S stock evo parts
i have a few things for sale they are off my 05 evo with 26k on it
stock injectors one needs o-ring cuz the moron at kline messed it up when they warrantied them. so the injectors actually have 12k less then the rest of the stuff. looking to get $75 for them
heres the messed up one
next i have the stock turbo . its a td05 16g with the big 10.5 hotside. also when i replaced the manifold with a header the bolts and studs broke .off in the turbo so i had to drill them out . actually used the plasma on one . it looks messed up but its really not ran it on the car for about 14k with no problems at all . so to install the turbo you must use nuts and bolts that go through the flange .looking to get $350 for the turbo
and last is a megan racing header . it has a bung welded into it for a autometer egt gauge. used stainless rod when tig welding it so the bung wont rust either. looking to get $125 for it the header will come with the gaskets it came with from megan racing . they are brand new. i recomend buying oem gaskets .
thats it for now there may be more stuff later
Evo2NV is offline   Reply With Quote
