Old 03-17-2007   #1
SLOW_V
2.4 lower block question
I have a 2.4 lower block from 93 eagle summit. Could this be used with the 1g head? Any advice will help.
SLOW_V is offline   Reply With Quote
Old 03-17-2007   #2
Re: 2.4 lower block question
Yup, that's a 4GCS, there's several members that are using them here with turbo applications. You'll want to put in aftermarket rods and pistons and get the block cleaned up, but yea, it'll work!
Old 03-17-2007   #3
Shane55113
Now 20% less Racist
Shane55113's Avatar
I think that is was just a 4g64, i thought the G4CS was out of old 2.4L na galants with DOHC.
Old 03-18-2007   #4
iceminion
iceminion's Avatar
The G4CS was found in the early 90s Sonatas.
The 4g64s were in galants/expos/summits and the 96 Eclipas Spyder non-Turbo.
In 92.5 mitsubishi switched designes from the 6 bolt to the 7 bolt, 4g63 and 4g64
Your 93 mitsu 2.4l may be a 7 bolt, this is easy to find out, sans tranny
I have heard mixed results from the 2.4 7-bolt, I personally would not build up any 7-bolt motor, although I have heard that if you know what you are doing, any 7-bolt can be as strong as a 6-bolt if you build it right.
building a 3000GT AWD Turbo.
Old 03-18-2007   #5
Aren't these sentences contradictory?
