Old 03-19-2007   #1
Weird misfiring problem.
My car is a '92 gsx, mostly stock except for a small 16g, and a MBC. It first happened on saturday, and has happened one more time since. Both times it happened, I went to a store, and on the way there, everything was perfectly fine. When I went to leave, it was idling very rough, and when I went to drive away, it was running like it dropped a cyllinder. I drove for a couple blocks, and it didn't go away, and turned on the CEL, so I pulled into a parking lot to check if something had come loose or something, but everything was perfect. By the time I got back into my car, the CEL had gone out, and it was running normally. I looked everything over, and everything seems normal, so I have no idea what could be causing this. Does anyone have any suggestions?
Old 03-19-2007   #2
91autoeclipse
Re: Weird misfiring problem.
have you look at my no starting problem.. I'm still trying to test the coil pack and power transistors looks like i might have to take it to a shop to find out what is really wrong.. MAP.. is not that far.. so I might just give them a call..
Your cars problems and mine could be related.. or similar issues.
91autoeclipse is offline   Reply With Quote
Old 03-19-2007   #3
Transistor pack, coil pack, plugs/wires.
Old 03-19-2007   #4
Go outside(when its dark), Start your car and spray some amonya(SP?) water(or windex I believe) on the plug wires. Amonya water "helps" the plug wires arc. If you see arcing then replace the wires.
Old 03-19-2007   #5
Just touch the wires while the car is running, if you get shocked you should replace the wires, a lot more fun then spraying some windex water at them.
Old 03-19-2007   #6
Haha! I did that once, it scared the crap outta me.
Old 03-19-2007   #7
They're brand new Accel wires, so I doubt that's the problem. I'll look into the coil pack/transistor pack.
Old 03-20-2007   #8
bring it up and we well get it fixed
Old 03-20-2007   #9
My car behaved exactly like this when the MAS plug had some corrosion on the pins. A little contact cleaner took care of the problem.
Old 03-24-2007   #10
Ok, I've changed out the resistor pack and coil, checked the mas plug, and the problem is still there. I'm thinking my ecu is in the process of taking a shit. Does anybody know of any other things that could possibly be causing this?
Old 03-27-2007   #11
No other suggestions as to what could be causing this? Recently the problem seems to be getting worse.
Old 04-01-2007   #12
skyhigh350
Send a message via AIM to skyhigh350
Sounds like an ecu to me.. They can cause a ton of issues..
skyhigh350 is offline   Reply With Quote
Old 04-01-2007   #13
x-pride
x-pride's Avatar
Is the CEL still on? If so, what code did you get. Oh by the way just a side note. If you kept the orignal MBC when you bought the car. Make sure you recheck the way it was hooked up. I remember it having a hole in the brass connector or metal connector. The only reason I know is becuase I was talking to the owner and he was telling me how his car sucked at the track. I told him about the problem and I don't know if he fixed it or ignored what I was telling him.
Old 04-02-2007   #14
It's supposed to have that.
Old 04-23-2007   #15
Finally figured out what it was. It turns out that one of the injectors was bad. I threw the set of 450's from my Talon into it, and it cured the problem. So my guess is that once the injector got warm from the heat of the engine, it wouldn't start working once it had stopped.
Old 04-23-2007   #16
johnson
johnson's Avatar
Drives: 90mitsu
i second that.. if its a good mbc it should have the little pin hole..
Old 04-23-2007   #17
johnson
johnson's Avatar
Drives: 90mitsu
strongly suggest that plugs/wire area...even injector too..
Old 04-23-2007   #18
Maybe you missed it, but I just posted that I already figured out that it was a bad injector
