Old 10-21-2003   #1
mxjosh711
Guest
Tournaments Won: 6
Posts: n/a
hey im new to this site and all, i have a boost guage and have no clue on how to hook it up, its a autometer phantom series, i have air fuel ratio as welll, any guys in kc wanna make alil extra cash and hook them up? let me know,
Old 10-21-2003   #2
Its pretty easy to do. With the pod it should only take a half hour or so to hook them both up. The fuel pressure solenoid is the best spot to hook up the boost gauge.
If you don't already have it you will need some nylon hose and a T connector to splice into solenoid hose.
The air to fuel gauge even though they don't actually do anything except look like a blinky blinky light, it taps into the wiring harness the goes into the ECU.
http://www.myzero.com/gauges/fps.gif
Thats the diagram for the fuel pressure solenoid. This is for a 1G, you didn't specify what kind of car you had. But they are pretty much the same, the 1G have one more hose I think.
For the air to fuel gauge you will the need the wiring pinout for your type of car and then tap into that. I am sure if you specify what kind of car you have somebody will have the diagram for you.
CRAIG
Old 10-21-2003   #3
You can go to vfaq for a wiring diagram if needed.
Old 11-05-2003   #4
Mike_91_TSi
Guest
Tournaments Won: 6
Posts: n/a
I used this page for my reference.
Finding O2 wire
Old 11-05-2003   #5
Lunar Eclipse
Guest
Tournaments Won: 6
Posts: n/a
Regular A/F gauges are worthless, don't even bother hooking it up. Sell it and take your mom out for dinner (seriously, it will do you more good).
Old 11-05-2003   #6
They are not totally worthless. You can check on the fly if you are running really lean or rich. I wouldn't tune on one though.
