Old 04-01-2007   #1
skyhigh350
Send a message via AIM to skyhigh350
To run or not to run
Well I just redid my whole engine. 91 6 bolt 2.0 n/a 5 speed. New pistons and had the crank turned and block bored.. New head, and everything.. I put the engine in today, it wont start. It cranks well ,however out of 5 seconds of cranking it will jump like its trying to run. Then it dies and repeats again. The gas is only 4 months old. Does this sound like a timing issue? This is my 3rd time timing a 4g63 and it looked perfect... Wires are in the right place etc. I replaced the ecu 6 months ago as well.. Any ideas??
skyhigh350 is offline   Reply With Quote
Old 04-01-2007   #2
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: To run or not to run
Did you adjust the cam sensor?
Originally Posted by shoutbox
Old 04-02-2007   #3
skyhigh350
Well, it was timing.. I got it running.. for 10 minutes.. It ran great.. The stopped with a thud.. Valves are ok.. I think it spun a bearing... The machine shop is gonna hate to see this one again..
