Old 04-02-2007   #1
Talon628
Talon628's Avatar
Problem!!??
So I took my GSX 97, out for the first day so that I could try to street tune a little,I have alot done to it, I started going it ran fine all the way across town. then I sat, let it idle for a bit, then it began to run rough and the check engine light came on and it died. Couldnt get it to start again, it would just rumble and die again. Im thinking it could be a sensor,maybe the o2 or somthin. not sure wondering what you guys might think?????
YOU GOT MY MONEY!!
Talon628 is offline   Reply With Quote
Old 04-02-2007   #2
tim
tim's Avatar
Re: Problem!!??
Were you logging? I assume so since you were tuning. What do the logs say?
Old 04-02-2007   #3
DSM_421
Re: Problem!!??
I had the same thing happen to my old dsm. All it ended up being was a dead alternator.
Old 04-02-2007   #4
Talon628
Talon628's Avatar
Re: Problem!!??
yah I was logging, everthing was perfect little rich but otherwise good. Yah I was kinda thinking somthing electrical, the way it happened, it was so abrupt. Cause my check engine light never goes off, only when engine sensors and such start fuckin up. I dont know about the alternator cuz it seems im gettin plenty power. It take a second to start like no fuel coming, then starts,idles good, then goes into a sputter then dies.
YOU GOT MY MONEY!!
Old 04-02-2007   #5
Talon628
Talon628's Avatar
Re: Problem!!??
could use a lil help on this one.
YOU GOT MY MONEY!!
Old 04-02-2007   #6
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Re: Problem!!??
How's the maf sensor?
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 04-03-2007   #7
bluntedelvis
Click,Click,BOOM!!!
bluntedelvis's Avatar
Re: Problem!!??
Fuel pressure regulator?
Old 04-03-2007   #8
Talon628
Talon628's Avatar
Re: Problem!!??
the MAF is good checked that. The AFPR is set to 43 psi.
YOU GOT MY MONEY!!
Old 04-03-2007   #9
bluntedelvis
Click,Click,BOOM!!!
Re: Problem!!??
Clogged injectors, you said it sounded electrical any other thoughts to support that? You mentioned your Check Engine light never goes out unless sensors and F'n up which is weird uselly it's the other way around. I'd go and plug in and read codes.
Old 04-03-2007   #10
Re: Problem!!??
Try flooring the throttle while cranking. That will cut the fuel off and clear it out if it is flooded. It could be the coolant temp sensor.
Old 04-03-2007   #11
Re: Problem!!??
Your engine needs 3 things to run, fuel spark and compression, if it starts then dies its probably ignition related, transistor pack/coil pack/plugs/wires.
Old 04-03-2007   #12
Talon628
Talon628's Avatar
Re: Problem!!??
Im starting to think maybe I jumped my timing. The belt was kinda loose and now that I think of it the last thing I did was rev it a lil before it started acting like shit. But im also goin to check and see if all the spark plugs are sparking. Make sure my coilpack didnt go out. and I would plug in but my obd 2 plug dont work so this is kinda time consuming.
YOU GOT MY MONEY!!
Old 04-03-2007   #13
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Re: Problem!!??
Why would you even CONSIDER starting the engine with the timing belt "kinda loose"
