Old 04-03-2007   #1
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Alternator interchange between Turbo and NA?
I have been having electrical troubles with my car lately. Every once in a while this problem happens. The cars electrical system dies. It has to be the battery or the alternator. I had them both checked lately, the battery at sears and the alternator at redrooster where they hooked up something to measure the draw. Both checked out fine.
However the car doesn't seem to be holding a charge. Started the car up this morning, drove a short distance, the wipers were going slow, then the radio died, shut the car off and tried to start it again and it just turns over very slowly...
So since the battery checked out fine, I am thinking it is the alternator isn't putting out consistanly... any other ideas what it could be??
This car is a 1993 gs and I am going to try to swap alternators from a turbo and I don't know if they are the same
