Old 04-10-2007   #1
Kougar
Drives: 06 RSX
FS: 88 starion 5sp, light mods, no rust $2500 OBO
Taking a different path in life right now. Need to get away from the "spend, spend, spend" mindset and save up for once in my life.
VIN: JA3CC54N6JZ014682
Anyway, it's a 1988 Mitsubishi Starion SHP, 5sp, 159k on chassis, 28k on engine (was told stock rebuild, ~140-145 across all 4). No rust, frame rails are pefect. Paint is great on parts of it, other parts are peeling - bumper and hatch. Missing airdam too.
Right now the car has the SHP 9" rears but 7" fronts, because one of the SHP 8s was smashed pretty good and made the car pull. I STILL HAVE THE 8s if you want them.
Interior is a bit worn, in that the leather shows it's age. A few small tears in front seats. All interior is intact otherwise. A few small leaks, oil pan gasket, possibly front cover on part of it, and something off the back of the engine. Not sure if rear main, front tranny seal, or valve cover leaking downwards. I removed cruise; it binded up on me one day so i cut the wire where it connects to the pedal (no other option at the time). I took the module out of the bay also. The rear axle seals are torn. Nothing is clicking, and I have a spare axle that goes with car. The other side JUST broke open a few days ago. You can get away with putting new boots on it probably. All Emissions come with car also, as do various other parts that have been taken off.
All new tires, plugs, wires, silicon vacuum hoses, radiator hoses, recently changed 10w40 oil w/ napa gold filter, new CTS, engine fuel filter, and PCV valve. It runs good right now, stops good, turns good, shifts good.
Current Mods:
- 1G MAS w/K&N
- KDM 3" AHP
- KDM passenger side hardpipe
- 2.5" turbo-back side exit exhaust
- KDM Chrome OVCP w/Turbo XS-RFL BOV
- SS Braided Turbo Oil Feed
- Hallman Pro MBC
- MSD Blaster 2 coil
- EGR Blockoff plate
- ABS delete
- Removed emissions
- Vacuum line removal
- 20% Window Tint
- PIAA fogs + headlights
- LED running + side marker lights
PS: Pics are BEFORE polish and wax were applied. In other words, it'll look great when fulled detailed.
I am asking $2800 right now. However, if you want it cheaper I can pull some mods off of it. Let me know through a PM
