Old 04-11-2007   #1
Talon628
Talon628's Avatar
MAF-T tuning.
My setup: 60-1 t3/t4/full exhaust.,walbro 255, AFPR 1000, PTE 680cc injectors, MAFT gen1 w/3" GM mas.
So yesterday I put in My boost gauge,water temp,and wide band o2. I went to go try, and lets say make sure i can drive it(tune). so I got it pretty good just by watching the wide band,(no I dont have a data logger cuz my obd 2 plug is broken on the car)and got it to idle stoich/rich, then got it to run the same at WOT. But the question I have is,can I adjust it for partial throttle? Because like when im only a little on the gas it will stay almost lean, only until I stomp the gas will it begin to richen out. Or if that is normal....Because I noticed the turbo would spool at partial and yet it still reads lean, and then when floored it'll read rich.
That and also, when I keep it in gear, but let off the gas it leans out? normal or odd?
YOU GOT MY MONEY!!
Talon628 is offline   Reply With Quote
Old 04-11-2007   #2
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Re: MAF-T tuning.
Never tuned a MAF-T, so I can't answer most of your questions. But the leaning out when you let off the gas is normal. When you let off the gas, and the engine isn't at idle, it shuts the injectors off
Old 04-11-2007   #3
Talon628
Talon628's Avatar
Re: MAF-T tuning.
ok so that helped a little..damn any one else.. need to figure this out.
YOU GOT MY MONEY!!
Old 04-12-2007   #4
Re: MAF-T tuning.
Fix your OBD2 plug.
Old 04-12-2007   #5
Talon628
Talon628's Avatar
Re: MAF-T tuning.
great that was awsome advicelol, If you know exactly how to fix it you should send me a illistrated DIY directional guide. That would be nice, thank you. Other wise if anyone else on here has tryed this gimmie some input.
YOU GOT MY MONEY!!
Old 05-01-2007   #6
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: MAF-T tuning.
Besides the MAF-T box do you have any other thing tuning the car?
The box works pretty well but there are better tuning methods and you have the wide band so thats a good start.
The thing I don't like about the box is that there are only 3 knobs
Idle
Mid throttle
WOT
IMO that is not enough to tune a car properly (make it run, yes but provide a good consistant tune, no)
I would look into something to tune with the box
An S-AFC II
DSMlink
MegaSquirt
Looking at your setup it is time to take it up a notch on tuning
Old 05-01-2007   #7
Re: MAF-T tuning.
Idle
Mid throttle
WOT
IMO that is not enough to tune a car properly (make it run, yet but provide a good consistant tune no)
An S-AFC II
DSMlink
MegaSquirt
A simple wire tap to the CAS and you can then tune via RPM as well.
Old 05-01-2007   #8
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Re: MAF-T tuning.
Also, it's actually just:
Low
Mid
High
or however they break it down. They high on the basic air flow tuning doesn't necessarily mean WOT. It applies to any time you reach a certain point in airflow (800hz maybe???).
You should be able to tune for these three ranges, and then as Nite said do a different tune based on RPM which kicks in at WOT.
