Old 05-03-2007   #1
gsxguru
FS: 1992 GSX (white)
It is a white 1992 Eclipse GSX that I am the second owner of since June of 1997 (first owner was a lady from Hasting MN). The car hasn't seen a winter since 1999. I have complete records since then including receipts (most) of everything done, date and mileage at the time of the part installed. I have never cared much for drag racing. I have attended no more that two dozen open track events including the former AARRF events and Corvettes of MN.
Enough sentimental stuff - here's most of what's on the car:
1992 Eclipse GSX with 86,700 miles - no winters since 1999
Engine:
  • Head = just installed - remanufactured - 3G lifters
  • 6-bolt block (1 over bore) 2G cermic coated pistons
  • Cometic Head Gasket
  • ARP Bolts throughout
  • AWD tranny with upgraded internals - rebuilt with updates at 81,400 miles
  • ACT 2300 installed, slightly used ACT 2600 comes with it
  • ACT light flywheel
  • LSD Rear (4-bolt)
  • ABS
  • 2G MAS with Dejon intake and K&N
  • Big 16G turbo (seals good)
  • 550cc RC Engineering Injectors
  • J pipe
  • Buschur FMIC
  • SPAL fans (2)
  • TB seals replaced
  • Ported 2G exh. man.
  • Ported 2G O2 housing
  • Archer Racing 2.5 downpipe
  • Buschur 3.0 cat back
  • Fluidyne Radiator
  • 90 oil cooler
  • 90 oil filter housing
Suspension:
  • KYB AGX with Ground Control Coilovers
  • Ground Control Adj. Camber Plates up front
  • Ingalls Rear upper control arms
  • Eibach Springs (550F 450R)
  • ST Rear Swaybar
  • Front STB
  • Two piston brake calipers with correct proportioning valve
  • SS lines
  • Powerslots
  • 17" Konig Villans & 16 American Racing Spyders (plenty of tire left on both)
  • Energy Suspension bushings (except subframe)
Electronics/Gauges:
  • SAFC (Gen 1)
  • EPROM ECU with Technomotive Stage III
  • FP rewire with Walbro
  • Pocketlogger with Palm 125
  • Boost, EGT, Oil Temp, Oil Pressure, Water Temp (A-pillar and center vent)
  • White face stock gauges
  • Apexi Turbo Timer
  • Racer Wholesale Inj. Duty Cycle/AF gauge (blinky lights)
Misc:
  • Carbon fiber hood vent
  • Holes cut in seats for 5-point harness
  • Interior is AWESOME except the seat which I cut for belt grommets
  • Exterior is 8 out of 10 (couple scratches mostly on plastic, no dings/dents, no visible rust)
  • Flip-up Sun Roof not factory
This car handles awesome, very neutral (no oversteer/understeer). Buried speedometer at Brainerd 145mph+ with in-car video to prove it. I have never been in an accident with it - never off track.
AC Removed
Cruise Removed (have parts)
Ken Schlorf
GSXGURU
Some of these pictures are a little old and only show the Spyder rims (note photo descriptions):
http://www.mitsustyle.com/photopost/...00&ppuser=1651
gsxguru is offline   Reply With Quote
