Old 05-09-2007   #1
driftn1g
maf translator
if i get the GM maf with the 18 dollar convertion harness.. do i need a translator??
Old 05-10-2007   #2
x-pride
x-pride's Avatar
Re: maf translator
Yes you will need the translator.
Old 05-13-2007   #3
marcell6492002
marcell6492002's Avatar
Re: maf translator
It is worth the money!
marcell6492002 is offline   Reply With Quote
Old 05-13-2007   #4
x-pride
x-pride's Avatar
Re: maf translator
It really depends on what your setup is. If you have everthing stock than no but if you already upgraded everything than yes. That is if you are over running your 2G mass.
Old 05-13-2007   #5
driftn1g
Re: maf translator
1g mass, but im trying to get at least 300awhp out of the stock block, stock turbo
Old 05-13-2007   #6
x-pride
x-pride's Avatar
Re: maf translator
GL on getting three 300 AWHP out of the stock turbo. Upgrade everything else before you upgrade the turbo and mass. I think one of the first thing on you agenda should be getting a Eprom ECU.
Old 05-13-2007   #7
Shane55113
Now 20% less Racist
Shane55113's Avatar
Re: maf translator
you could probably do it with Race gas, a nitrous kit, and dsmlink.
Old 05-14-2007   #8
driftn1g
Re: maf translator
21psi, supporting mods, its possible
Old 05-14-2007   #9
x-pride
x-pride's Avatar
Re: maf translator
Most unlikely not but GL.
Old 05-14-2007   #10
driftn1g
Re: maf translator
I should have an eprom ecu already..
regardless, first gear hub and sleeve need to be replaced before anything
Old 05-14-2007   #11
Re: maf translator
You aren't going to hit 300 awhp on a 14b without nitrous. You can still have a quick car with under 300 awhp. Start losing some weight, that is free and makes a difference, not to mention it helps save the drivetrain.
Old 05-14-2007   #12
driftn1g
Re: maf translator
Old 05-14-2007   #13
Re: maf translator
You can hit 300awhp on a Dynojet AWD, but probably not on a Dyno Dynamics or Mustang.
