Old 05-14-2007   #1
iceminion
iceminion's Avatar
eBay SSAutochrome Manifold
So I did the dirty deed, I bought an eBay stainless steel tubular manifold for my GVR4 for $100 shipped. I plan on HEAVILY reinforcing it before I install it, I am ok with pulling it off and re-welding it, I understand that I may eventually end up with more weld then pipe....too late to return it.
I spend alot of time on the couch caressing a DNP manifold for a month or so before actually installing it on Mug's project car.
the manifold I have now is shitty, just plain shitty, the t3 flange needs to be milled flat, it looks like a cave man made this POS.
-BUT- if it works, then cool.
(the first pic is a NIB fidenza flywheel I got off tunerz for $120 shipped, I am much happier with this deal)
ID:	5653   Click image for larger version
ID:	5654   Click image for larger version
ID:	5656   Click image for larger version
ID:	5657   Click image for larger version
ID:	5659   Click image for larger version
ID:	5660   Click image for larger version
building a 3000GT AWD Turbo.
Old 05-14-2007   #2
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Re: eBay SSAutochrome Manifold
Well as long as you know that it needs to be braced, and is probably going to be re-welded multiple times, then hooray!
Old 05-14-2007   #3
The flange will falten out when bolted to the exhaust housing, they might break though from stess, re-welded as cracks form.
Old 05-14-2007   #4
Yep, *IF* the flange will flatten out when bolted up, it will have stress in it and more than likely break the weld later on. They could spend another $50 and make those decent manifolds. Trying to fix them after it is made is much more difficult though.
I would get some 3/8" stainless rod and put a few braces on there, one on each end, from flange to flange, then a few others in there. I would then have it heated and cooled a few times (to 1200* F), then have the flanges ground flat. That will be your best chance without redoing all of their welds too. The thin tubes are a big part of the problem too, and there is not fix for that.
Old 05-14-2007   #5
b00stcreep21
I hate everyone
Too thin of material, not enough heat, and not enough fill rod=
Old 05-15-2007   #6
There's always a reason why it only cost $100.
Old 05-15-2007   #7
Glad I bought the new FP cast mani. You could hang a bus off the end of it.
Old 05-15-2007   #8
Onefast99gsx
If you're gonna be doing some heaving welding on that, you may want to make a plate to clamp or bolt that flange too. It will help transfer the heat and less likely to warp welding on it.
Old 05-16-2007   #9
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Why didnt you spend another $200 for an OBX Ebay one. At least those last more than a day.
'04 Honda Ricer: stock
Old 05-16-2007   #10
driftn1g
lol
Old 05-16-2007   #11
Wow, that manifold is freeakin sweet!
Old 05-16-2007   #12
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Doesn't Chris have pictures of his that he bought before heading out to the Shootout like three years ago?
Seem to remember it was welded once right after he got it, then the wastegate mount fell off on the way home, and then the whole collector fell apart and was held on by hoseclamps just to get home.
Old 05-19-2007   #13
96tsiawd
96tsiawd's Avatar
Of all the rigged things you've done Alex this has got to be one of the jehnkiest.
96tsiawd is offline   Reply With Quote
Old 05-19-2007   #14
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
lol. Rippin' on alex FTW!! Saw the manifold the other day, looks like a tubular mani..nothing special. Who wants to take bets on how long it will last?
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
