Old 06-03-2007   #1
stcloudgsx
stcloudgsx's Avatar
Send a message via AIM to stcloudgsx Send a message via MSN to stcloudgsx
Computer Problems
My computer will not boot up when I power it on, but all of the lights on my case turn on. The disc drive lights flash on and off every second or so and actually lose power when the lights turn off becasue if I try to open them they do but the drawer stops whenever the light is off. So my question is, what could the problem be? I'm thinking the power supply is the culprit but I'm not very sure. Thanks
Anthony
stcloudgsx is offline   Reply With Quote
Old 06-03-2007   #2
Re: Computer Problems
open it up make sure the CPU heatsink is plugged in and attached. We had a recent computer problem at my work and that turned out to be the problem.
Old 06-03-2007   #3
Onefast99gsx
If it's an ATX style motherboard, you can try this diagnostic on the power supply
http://www.fonerbooks.com/power.htm
Old 06-03-2007   #4
stcloudgsx
stcloudgsx's Avatar
Thanks a lot for that website, I'll check all of these things once I get off work. The CPU is liquid cooled so that rules out the CPU fan. Thanks for all of your help.
Anthony
Old 06-03-2007   #5
92EvilTalon
3.1L v6 power...
92EvilTalon's Avatar
Pit Stop Challenge Champion!
You can unplug your CDROM drives ... if you can get into the BIOS set the boot first option for your main HDD. Then uplug the drives. If it comes up with out the problem then its them. If it still does it. Plug them in one at a time...even your HD do the same. But like that site tells ya. Its a trial and error. Your PSU should be fine if it turns the whole thing on. Granted you could have a bad plug on it.
Josh LaCroix
