Old 02-09-2004   #1
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Is there much of a difference in the walbro 255hp and non-hp? I want a fuel pump that flows well but I don't want to buy a fuel pressure regulator. I don't plan on going huge on boost and don't think I would adjust the FPR. I was thinking of getting a 255 non hp. Would that be fine with a stock 2g FPR or would a 1g FPR be an upgrade if it fits?
Thanks
James
7/25/09
Old 02-10-2004   #2
The 255 non-hp will have all the same fuel overrun problems of the 255HP without the added benefit of more fuel flow at high boost levels.
Old 02-10-2004   #3
If you don't want an AFPR, try and scrounge up a Denso 190 and rewire it. You could always get the Walbro 190 too.
Old 02-10-2004   #4
Sorry for the off-topic, but what is the advantage of the Walbro over the Denso?
Old 02-10-2004   #5
It is the other way around, Denso is better than Walbro except for price. They are quieter and more reliable.
Old 02-10-2004   #6
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
Even a 190 can overrun the stock FPR after a while. I had an un-rewired Walbro 190 start overrunning my stock FPR after having it for about a year.
2G FPR's might be better?
Old 02-12-2004   #7
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
What happens when you overrun your fuel pressure regulator? Would you just run more base fuel pressure?
Could I go walbro 255 high pressure, get a bm regulator and turn the fuel pressure up? Higher fuel pressure would let me lean out the injector signal signal more. See any problems with this?
Setup is currently boost gauge, mbc, upper ic pipe w/ blitz bov, supra mkiv ic, and SAFC. I am wiating to put on my 14b and plan on getting 550's. Will the added fuel pressure be too much for this setup?
7/25/09
Old 02-12-2004   #8
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
anybody know?
7/25/09
Old 02-12-2004   #9
You can do that.
The problem of overruning the FPR makes it so that it can't ever run low pressure. So at conditions when your at high vacuum like idle and light cruising, you run a little too rich.
