Old 10-21-2003   #1
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
So I need a new turbo. My 14B is only good for pouring blue smoke out my exhaust at full boost.. So I have been looking around and with the money I have I think I have chosen a 16G. I then noticed that a lot of people are selling the EVO III 16G. Particularly they are a real good price from Forced Performance. I think this is the one I want.
I am also thinking about upgrading to a 2G manifold and O2 housing. I also want to find a manifold that is ported to me the 7cm opening. The question I have is FP also offers packages that include an EVO III O2 housing. Now should I just stay with a 2G manifold and housing or are there any fitment issues I need to worry about? Anyone running an EVO III anything(manifold, turbo, O2 housing)?
Thanks in advance,
Matt
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 10-21-2003   #2
You sure your turbo is the culprit? Maybe your valve seals or rings are gone... causing the smoke.
What year/make is it...
Old 10-21-2003   #3
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
She's a 92 TSi AWD
I have thought that too. I had Rick from MN board look at it and he thought it was more the turbo than anything. My compression test was great for having 168K on the motor. And the smokle is only there at high boost and when it sits at idle for more than a few minutes and I hit the gas.
Matt
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
Old 10-21-2003   #4
v8klla
v8klla's Avatar
Hey Matt! How's it going, well besides the obvious problems!
As far as the Evo Big 16g I have heard very good things about it on the DSMlink forums...One guy is flowing 40+ lbs/min of airflow, which is good for approximately 400+ horsepower. Spool up should be pretty quick and power is very good. And with the prices as low as they are you can't beat it!
The only thing I would look into is a 50 trim...You can get the entire kit for $999 from extremepsi.com but if that is too much and/or too big for you I would definately go with the Evo.
Just to let you know I am selling my ported 2G O2 housing...Never had any boost creep on my Big16g!!! Let me know is you are interested...
Chris
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 10-21-2003   #5
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
C'mon, I am a manager at Circuit City, I don't make money...! I am pretty sure the EVO 16G is going to be the one I can afford. And I am more than interested in that O2 housing. I get creep on this smoke blowin 14B and that should help... Let me know what you want for it.
Matt
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
Old 10-21-2003   #6
See the Elite forums right now for their Turbo special for the DSMStyle members!
Old 10-21-2003   #7
FORSFED
Hey Matt, good choice on the 16g. When I had that on my car it made a world of difference over my falling apart 14b. Don't bother looking into anything larger like a 50 trim as that would be overkill on your car right now. You'd really want the supporting fuel mods and fmic before going any larger than a 16g. Speaking of which you'll need to keep in mind that you'll have to watch your fuel and boost level. With winter near that bigger turbo plus cold air will mean you might be hitting fuel cut without any upgrades in that area. You may want to check into a 2g MAS and safc to go with those 510cc injectors you have.
As far as comparing the three 16g turbos, I can't tell you much since I've only had experience with a big 16g ported and clipped. One thing I do know is that if you purchase the monster evo o2 housing, the outlet will not reach your downpipe the same as a stocker and you'd need to have the exhaust re-fit to it.
Old 10-22-2003   #8
It also sounds like it may be your valve-seals, it is almost deffinately not your piston rings. Does your 14b have any shaft-play? The EVOIII exhaust manifold and big 16g are a good choice, but I would go with a 2.5" tubular o2 housing rather than the cast thingys since they flow better (and you won't have any fitment issues as you would with the EVOIII o2 housing).
Old 10-22-2003   #9
I dont know where you are checking out the pricing but try edited. they are local DSMers. He comes into my work once in a while.
*Only 3 shops get props here at this time. You can PM him with your link if you want, but personally I'd skip the whole 16G and get right to the PTE. - DSMStyle*
Old 10-22-2003   #10
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
I haven't had the chance to pull it yet. But I will soon to put on the 2G housing I will be getting. What am I looking for? (Keep in mind I have very little turbo experience)
How do I test to see if the seals are bad?
Thanks,
Matt
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
Old 10-22-2003   #11
Ok I am sorry but that is really fucking lame. So now we can't name other DSM shops on the board? What if I told this kid that I love my TRE turbo, or maybe he should get one from FFWD since they do awsome port-work?
Old 10-22-2003   #12
With a bigger turbo comes more money needed. What is wrong with a big 16g? If he gets a PTE turbo, he has a lot of money he would still need to spend. His profile says 2.5" exhaust. He would have to spend a couple grand in supporting mods after buying the turbo (FMIC, 660's or better, SAFC, fuel pump, etc). A 16g is a good budget turbo. Good power and not a big kick in the bank account.
Old 10-22-2003   #13
Originally posted by TalonTSiDude+Oct 22 2003, 10:21 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (TalonTSiDude @ Oct 22 2003, 10:21 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-92tsiawd84@Oct 22 2003, 07:02 AM
*Only 3 shops get props here at this time.&nbsp; You can PM him with your link if you want, but personally I'd skip the whole 16G and get right to the PTE. - DSMStyle*
Ok I am sorry but that is really fucking lame. So now we can't name other DSM shops on the board? What if I told this kid that I love my TRE turbo, or maybe he should get one from FFWD since they do awsome port-work? [/b][/quote]
Next time you have issue with something I do on this board come to me please. I edited it out for a reason. YOu can name, TRE, Buschur, RRE, Team Rip, AMS, ect ect ect all day long. I don't have issues one bit on that. So If I do for some reason edit it out maybe I have a reason. Anything more about this please bring it to me directly and that goes for anyone else wanting to comment on it.
Back on topic or it gets deleted.
WooT! Go John Haley Motorsport! :stick:
Old 10-22-2003   #14
v8klla
v8klla's Avatar
I have to agree some what with Chris...Although I love this site and the people within I must say that editing a post stating a better price is going a bit too far for my tastes...I just saw your last post Allan, maybe you had alternate reasons?
And if it makes a difference I wrote this while you posted your last time...So I didn't do this after reading your post...Sorry.
And a Big16g is a good investment...Especially for $400 less that a PTE...not to mention it is a direct bolt on for a 1G, nothing else needed...
Chris
P: 763-545-3800
Old 10-22-2003   #15
How do the 16G owner like thier power they are acutually getting and times off the 16Gs? compare to what they can do with the 14b. I myself am going to be using a 16g for Rally. I think there is too much thought being put into this. How does CVD liek his 16G now that he has been to the track, street, and dyno?
Old 10-22-2003   #16
v8klla
v8klla's Avatar
I have no problems with my 16g...And from what I have heard on the DSMlink forums at least one person is already making 400+ HP on the new Evo Big16g...Like to see that on a 14b
Chris
P: 763-545-3800
Old 10-22-2003   #17
CVD is running 12.45 on his small 16g with out a FMIC. He also dynoed 319 at the front wheels. I think that is pretty damn good. He planned on upgradeing to a 50 trim but money may not permit. If not, he may try a shot at the 16g record. A bigger turbo isn't better if you don't have the money to do the supporting mods.
BTW, I heard this 2 weeks ago from him at shooters.
Old 10-22-2003   #18
What is the 16g record?, He has a built engine though... well except ARP's lol
Old 10-23-2003   #19
I thought he said something about high 11's
Old 10-23-2003   #20
Chris
No I understand completely where you and Chris are comming from. Just a few things that where brough to my attention about that location that I wanted to clear up. Basicaly 2 diff member names from the same IP and the use of the PM feature. Abuse of the site so to speak. Again maybe I just didn't explain the way I should have upon editing it. My aplogies.
