Old 07-10-2007   #1
clutch's and flywheels
1. act 2600 (out of my talon) 15k on the plate 5k on oem disk 75.00
2. exedy stage 2 sprung 3 puck cerametallic (from the evo III) 75.00
from there site. ''EXEDY cerametallic button (SC) clutches are designed to accommodate the demands of high power modified engines. Our ceramic friction material will transmit increased levels of engine torque without slipping or fading given the correct application.
All EXEDY ceramic button clutch discs have sprung centre dampers to reduce the impact and shock load transmitted to the drivetrain, safeguarding the transmission and other drive line components.''
3. exedy 7bolt awd chrome ollie flywheel (off the evo III) will work on all 7bolts to 1999. 75.00
4. oem evo III 7bolt awd flywheel (lighter than oem dsm) 30.00
5 oem 99 gst 7bolt flywheel 30.00
