Old 02-12-2004   #1
-GSX-Falcon
Guest
Tournaments Won: 6
Posts: n/a
I just bought some used 450cc injectors for my upgrade from an auto setup to manual. Im missing one of those little black caps at the end of the injectors...and another is damaged. Is there anywhere i can buy a couple of those?
Also, Im going to be swapping in a manual ECU with my new injectors, so i have the correct fuel maps. Now, i have learned the FPR for automatics is set HIGHER then that of manuals. I got a whole fuel rail off a manual and thought i would switch it in so i would have the base fuel pressure that the ECU is set for. But now i hear that having higher fuel pressure can be a good thing because you can run more boost on smaller injectors. So should i keep the auto FPR and run a little rich but have a little more leway in the boost area, or run the manual FPR? Opinions?
