Old 07-13-2007   #1
driftn1g
coolant overflow
ok so i got this new car i picked up yesterday 1994 tsi awd..
i was looking threw the engine bay and i noticed that the coolant overflow tank is just chillin there, the electrical is not hooked up nor is the dump.. the line coming from the t-stat waterneck is connected to the bottle then the dump line is aimed towards the ground.
should i hook it back up to be safe?? where does that dump go to.. the rad??
Old 07-13-2007   #2
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: coolant overflow
The electrical should be hooked up unless they unplugged it because the sensor was shot or something. The t stat hoze should be hooked up to the overflow and then the dump should face the ground. It holds your excess antifreeze when the engine gets warmer since the fluids expand.
Amsoil Dealer
Old 07-13-2007   #3
driftn1g
thats just weird that the dump would be facing the ground..
will it hurt anything if its unplugged?
Old 07-13-2007   #4
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
it just wont tell you when the coolant in the resevoir is low...
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 07-13-2007   #5
driftn1g
meh seems like the electronics in these cars suck... i mean, i never got an oil light when my car seized.. you can even tell by the gas light
im going to hook it up the way it was, and try to hide it since it was logged in the IC piping and an engine mount lol
Old 07-13-2007   #6
DBMajik
There is an oil pressure gauge there. Now you know to check it.
DBMajik is offline   Reply With Quote
Old 07-14-2007   #7
x-pride
x-pride's Avatar
Most cars coolant dump tube do face the ground. It would be stupid if it faced the sky. Did you even buy a service manual yet? Not to be an ass but please step away from the car. It seems like you are still confused about working any kind of car not just DSM's. Please if you blow this one up don't go around like most Honda owners saying that these car sucks. FYI you should always be checking your oil each time you fill up on gas.
