Old 07-14-2007   #1
matt j
lotsa stuff for sale
alright guys i have some stuff laying around that i dont need anymore and would like to get rid of everything is best offer. all came off of a 90 eagle talon tsi
1g complete head- great shape, hasnt been ran since i got it back from the machine shop.
1g intake manifold painted black with polished efi
2g exhaust manifold no cracks worked perfectly on my car
2g o2 housing good shape
1g o2 housing also in good shape
2g black top 450cc injectors work good tested and all came back good
1g stock sidemount great shape
1g stock lower intercooler piping
14b turbo, needs rebuild or good for parts
14b wastegate, works good
1g rods and pistons compression tested before pulled apart 160 across the board
1g crank absolutly perfect
1g oil pan (turbo)
2g oil pan (turbo)
1ga stock foglights w/ brackets
1g water pipe with coolant line
1g 6 bolt flywheel stock good shape
2.5" uicp with greddy flange
33x9x2.5 fmic couple bent fins works great (upper intercooler pipe fits with this intercooler, have all pipes to run it)
safc1 worked great comes with stand
hvac box good shape
1g red driver fender, good shape can be sanded and primed if needed, couple scratches
1g water pump good shape has metal blade only used for 1000 miles
1g horsecock shifter
1g oil pickup with screen
i may have some other things also but thats all i can think of off the top of my head. Only reason for selling is i found that my front motor mount had busted the bottom mounting location on the block, so i decieded to pick up a new motor.
i am paypal verified
matt j is offline   Reply With Quote
