Old 07-22-2007   #2
Re: Auto to manual conversion
it is easy to do I have done it on the spyder when I made it awd
if you need the parts I have them
stering colom,shifter cables,shifter,brake and clutch petels,clutch master cylnder.
all you have to do is bolt it all in and drill 3 holes for the clutch master cylinder so that can be bolted in also. the only other thing you will need to run a line from the master down to the front frame rail and get a s.s. line to run to the slave cylinder.
