Old 08-03-2007   #1
justinhill
BetHiLow Streak Un-Censored Champion! League Bowling Champion! Snowboard Champion!
Drives: 98 gst eclipse
Send a message via AIM to justinhill
help my throttle cable
so last night i was driving and the bolt that holds the throttle springs came loose and flung out i have the 2 springs and the plastic thing so i put it back on and got a new nut to day and when i started the car it wasn't idling right the cable is loose is there any way i can tighten it up?
justinhill is offline   Reply With Quote
Old 08-03-2007   #2
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: help my throttle cable
There is an adjustment where the cable bolts to the intake manifold. just losten the two 10mm bolts and take the slack out of the cable. The cable adjustment isnt really for idle though. You might have to adjust your biss screw or check out the ICS.
11.35 @ 120mph
Old 08-03-2007   #3
justinhill
alright i fixed the problem thanks man thread can be closed
Old 08-04-2007   #4
This should be in the basic tech section, o well.
