Old 08-12-2007   #1
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
blew the weld again
So I posted a while ago about my turbo being extra laggy and then found out that I had blown the weld in my o2 housing. I've got an external wg on my manifold which allows for the top hole in the o2 housing to be welded. Anyways, I had that rewelded after I blew it the first time, and I think I've blown it again. I haven't yet pulled the turbo and taken everything out to make sure because I am way too lazy and don't want to. I also don't see the reason considering that has to be the problem. My only question is, should I just have it rewelded again or what? I mean I dont have the time or money to keep rewelding this stupid thing. What are you other externally gated guys doing? I've had a few ideas, lmk what you guys think.
-Fill the whole with melted steel and let it harden inside so it's thicker than just an 1/8 inch steel plate.
-lse has a 02 housing they sell that is just one big opening, but idk if that would work with an external wg.
Here's a pic of what it looked like before and what I assume it looks like again now.
pics or gtfo
Old 08-12-2007   #2
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Re: blew the weld again
LSE's o2 housing wouldn't work with that housing. You can either get it re-welded again, buy a new housing (actually not that expensive), or run an 02 eliminator that blocks off that port. There's plenty of options out there
Old 08-12-2007   #3
HiImBrian
HiImBrian's Avatar
I didn't really think lse's would work.
What would I need a new housing for? I'd just have the same problem with that one wouldn't I?
I like the sound of an o2 eliminator but idk anything about it. I'll start searching now, but feel free to fill me in while I look thanks
pics or gtfo
Old 08-12-2007   #4
HiImBrian
HiImBrian's Avatar
Figured out what it is. Basically it's either a tubular o2housing with a dead end pipe or i found a few that actually kinda run the o2 hole right into the other one and increases turbo spool. This sounds like a great idea but they are a little pricey.
pics or gtfo
Old 08-12-2007   #5
b00stcreep21
I hate everyone
You can get a new housing that doesn't even have that hole in it in the first place from precision
Old 08-12-2007   #6
HiImBrian
HiImBrian's Avatar
ooo That sounds a little cheaper than this
pics or gtfo
Old 08-12-2007   #7
b00stcreep21
I hate everyone
that still wouldn't help your situation. You need that port completley blocked off, that still leaves it open
Old 08-12-2007   #8
HiImBrian
HiImBrian's Avatar
^Your completely right. Haha I've I got what I pictured I would be way worse off than I am right now. Man I'm an idiot.
When you said precision has the o2 housing i need do you me pte? Cus I can't find their website for the life of me
pics or gtfo
Old 08-12-2007   #9
b00stcreep21
I hate everyone
Mmk, i liked about the housing. Lol. My bad. Basically, an easy way to do it would be to just have a downpipe flanged that covers up the port completley, and just has a bend coming off for the turbine wheel discharge. Basically what you have pictured above, just without that little connecting piece by the wastegate hole
Old 08-12-2007   #10
HiImBrian
HiImBrian's Avatar
not really. I don't have a down pipe. It's a custom turboback exhaust
pics or gtfo
Old 08-12-2007   #11
b00stcreep21
I hate everyone
Sorry, post edited
Old 08-12-2007   #12
iceminion
iceminion's Avatar
not sure if this would help you, but I am selling something that may work for you
http://dsmstyle.com/forums/showthread.php?t=16469
building a 3000GT AWD Turbo.
Old 08-12-2007   #13
96tsiawd
96tsiawd's Avatar
nice "bump" on the tial WG sale- hows the GVR4?
96tsiawd is offline   Reply With Quote
Old 08-12-2007   #14
Bring it to me and I will weld it up for you. It won't come off when I am done with it
Old 08-13-2007   #15
gofastman
James Bond... James Bond
gofastman's Avatar
Drives: 95 Jeep
Send a message via AIM to gofastman
any one know if you can you weld cast iron with silicon bronze?
-David C.
Originally Posted by bouncer07
If you know Mary Clifford, Ph,.D. Associate Professor of Criminal Justice in St. Cloud State University. Then your well aware of who she is.
gofastman is offline   Reply With Quote
Old 08-13-2007   #16
Bronze isn't going to take the heat well. Melting point is like 1150 degrees.
Old 08-13-2007   #17
HiImBrian
HiImBrian's Avatar
Well jet I'd take it to you but I'm planning on running close to 30 psi and idk if I trust it to hold. I wanna fill it up with steel if possible.
pics or gtfo
Old 08-13-2007   #18
Yeah, you're right. I don't know WTF I am doing.
How do you plan on filling it up with steel? It's just a block off plate.
Old 08-14-2007   #19
Just get the correct exhaust housing.
Old 08-14-2007   #20
https://secure.buschurracing.com/cat...roducts_id=420
That is what you are looking for. An O2 housing with a flange that completely blocks off your wastegate port.
