Old 08-18-2007   #1
what NEEDS to be plugged in for a 1g to run?
i am trying to fire up my engine, but i am getting no spark it seems.
I have just about everything plugged in at this time.
things that are not plugged in: 02 sensor, ac switch on thermo housing, knock sensor, speedo cable. thats all i can remember anyway.
the thing turns over fine but it wont fire up, im just trying to figure out why in very short order.
ideas are welcome!
Old 08-19-2007   #2
Re: what NEEDS to be plugged in for a 1g to run?
Ignition pack, transistor, coils, TB, temp sensors on T-stat housing and CAS. Of course plug wires and injectors too, but that is all I can think of.
Old 08-19-2007   #3
If spark is the only thing you aren't getting, then you need to trace the wires from the spark plugs back to the ecu-through all the parts. Do you have the noise supressor plugged in near the coil pack and transistor? do you have all the connnectors to the chassis connected near the ecu? There's a plug that supplies power to the coil-pack that is seperate from the ecu plugs, maybe you aren't getting switched 12v power to the coils.
Check your eci fusible link.
Just thought of something, did you istall the cam angle sensor 180 degrees off?
Old 08-19-2007   #4
Noise surpressor?
i am definetly not getting spark.
I thought about the cam angle sensor being 180* off, but i've heard that even with it on backwards the car should idle.
i'll check that MPI fuse thing by the ecu right now.
Old 08-19-2007   #5
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
if you need an MPI relay, I nave 2-1 is brand new. I just bypassed all of that, and got rid of them.
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
