Old 09-11-2007   #1
v8klla
v8klla's Avatar
Who else wants to reduce crankshaft vibrations and prolong engine bearing life?
Fluidampr Harmonic Dampers are your answer!
How does Fluidampr work?
Why your engine needs a damper
Each time the air/fuel mixture inside a cylinder is ignited, the combustion that occurs creates a torque spike that is applied to the crankshaft through the piston and rod. This torque spike is so severe that it not only turns the crankshaft, it actually twists the crankshaft ahead of its normal rotation and then the crankshaft rebounds. This twisting action is known as torsional vibration. When these torque spikes and forces get into phase with the natural frequency, critical torsional harmonic vibrations occur and can be seriously destructive to the bearings and the crankshaft. Dampers are designed to control those destructive vibrations.
Rubber VS Silicone Fluid
Critical harmonic vibrations occur numerous times in a engine’s operating range. Stock rubber and elastomer-type dampers are frequency sensitive “tuned absorbers”, and work at only one critical frequency. In the case of a stock rubber damper, it is tuned for a factory engine’s critical harmonic vibrations. If you change the mass of pistons, rods, or the crankshaft, you change the natural frequency of the crankshaft assembly; therefore, the stock damper is no longer tuned to the new frequency of vibration, and you may be headed for early failure of expensive engine components. Dampers also create heat while they work, and rubber is a poor dissipator of heat. This heat and the exposure to the elements deteriorates rubber, causing it to crack and change durometer, which then leads to inertia ring slippage, damper failure, uncontrolled torsional vibration, and costly engine parts breakage.
Damper Facts:
1.) Most stock dampers are actually tuned absorbers and do not work when the the engine is modified from the original set-up.
2.) The damper is not a balancer. It's job is to control torsional vibrations.
3.) The silicone inside a Fluidampr will not expire and is not effected by temperature change.
4.) An externally balanced assembly should be balanced with only the counterweight or stock damper installed.
What's the problem with a stock damper?
Stock dampers are tuned for maximum effectiveness with a stock rotating assembly when it's spinning at low rpm's. When the pistons, connecting rods, or crankshaft are changed or modified, or normal rpm range is increased, the effectiveness of a stock damper is reduced.
What are the key benefits of using a Fluidampr?
A good aftermarket damper protects your crank. Fluidampr is in a class all by itself, because it is designed to provide maximum control of all engine harmonic vibrations, regardless of the rpm at which they occur and regardless of the crankshaft's natural frequency. This translates to maximum protection of the crank, main bearings, related engine components and more consistent power output. Also, Fluidampr is maintenance and repair free. Fluidampr is effective on both race and street applications.
*Order yours today and get free overnight shipping!
http://www.maperformance.com/store/p...6&cat=0&page=1
*In stock items only, please contact us for availability.
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
