Old 09-24-2007   #1
eclipse_spyder
The most ricest dsm
removing steering wheel
How do you remove the steering wheel? I got the 18mm bolt out. I think it's a 18mm. Now its stuck and does not budge.
eclipse_spyder is offline   Reply With Quote
Old 09-24-2007   #2
Re: removing steering wheel
It is also pressed on, you will need a gear puller or steering wheel puller.
Old 09-24-2007   #3
A puller would help but its not a press fit.
Old 09-24-2007   #4
I've never used a puller. Just wiggle the wheel back and forth once the center nut is off.
Old 09-24-2007   #5
crazy_skier
A.E.K.Δ.B
crazy_skier's Avatar
Beer Dude 2 Champion!
Drives: 1994 Suburban
yeah I allways just wiggled and pulled on the wheel until it came off... so far its worked and thats on 2g's
Old 09-24-2007   #6
Make sure you paint or mark the wheel and steering column so you can get it back on the same way.
Old 09-24-2007   #7
eclipse_spyder
The most ricest dsm
What do you mean by that? Am I suppose to mark the small teeths?
Old 09-24-2007   #8
eclipse_spyder
The most ricest dsm
Was all of your guys steering wheel hard to get off?
Old 09-24-2007   #9
Draw a straight line with a permanent marker across the head of the shaft bolt, line that up with a line on the wheel. You want the wheel to be straight when you're going straight unless it's not that way right now.
Old 09-24-2007   #10
I had one that I was able to wiggle off and another that I had to use a puller on. Maybe there was some corrosion on it?
Old 09-24-2007   #11
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
I've always used a puller when I took my wheel off. But, I had access to one. I now have an aftermarket wheel, so lining it up, was tricky. Put it on, take it off, etc etc.
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 09-25-2007   #12
eclipse_spyder
The most ricest dsm
Where do you guys get your puller from?
Old 09-25-2007   #13
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
I always leave a couple of threads holding the nut on so I don't smack myself in the face with the wheel when it pops off. Isn't very pleasant.
Old 10-07-2007   #14
Project2G
Semper Fidelis
Project2G's Avatar
Drives: 1997 Eclipse GST
I have put on a momo wheel on both of my eclipse's and each time is was hard to pull off but ended up being able to do it. Just keep your wheels straight and that way when you put it on everything will line up correctly. Did you get your horn to work too? Just have yo make sure the little wire touches metal.
Old 10-07-2007   #15
eclipse_spyder
The most ricest dsm
I finally got the steering wheel to come off. I wiggled it a lot.
