Old 09-27-2007   #1
tnm27
I'm the short one.
tnm27's Avatar
New Motor problems...
Hey guys, i got done swapping out my old motor with a JDM Cyclone motor, but I ran into a couple problems, and I'm stuck as to what to do. The motor starts, but it's a really crappy start up, it jumps to 4k at the start than drops to 1k rpm, after that it idles really crappy for about 5-10 seconds than dies. While it's doing that, there is a loud whistle from around the intake manifold, I checked for air leaks, but can't seem to find any from around that area....or else I'm not just checking hard enough...I used a timing gun to check the timing and it's a little odd....Everything will be good, but after a couple cylcle's the timing marks start to jump like crazy. I fixed the CAS to the point where it doesn't jump too much but the timing is better than before. Should I redo my timing? what are any suggestions as to what the loud whistle is? Anything would help, Thanks.
2008 Mazda 3 (Daily Driver/family car)
1991 Mitsubishi Eclipse GSX...(on jack stands....still....) :)
tnm27 is offline   Reply With Quote
Old 09-27-2007   #2
Re: New Motor problems...
Are you trying to use the Cyclone intake manifold?
Old 09-27-2007   #3
Are you grounding the wire to check timing? Did you do an actual boost leak test?
Old 09-27-2007   #4
tnm27
I'm the short one.
tnm27's Avatar
No, I have the regular USD Manifold on there. Will that cause a problem? I've seen the same setup I have on other DSM's as well.
Old 09-27-2007   #5
tnm27
I'm the short one.
tnm27's Avatar
Yes, one to positive another to ground, and the third to the spark plug wire. no, I haven't done an atcual one, it's been about 2 weeks since i've been home to touch the car, but I will be there this weekend, I will probably conduct one than.
Old 09-27-2007   #6
No, there is a wire on the car that has to be grounded out so it won't adjust timing. VFAQ.com
Old 09-27-2007   #7
dragonforce
sounds like intake leak to me. check all of your hoses. try spraying carb cleaner around intake mani and hoses. your idle goes up if you have leak.
Old 10-01-2007   #8
tnm27
I'm the short one.
tnm27's Avatar
alright, i'll do that tonight after work.
