Old 10-14-2007   #1
BKs50trimGST
Post whore
Send a message via AIM to BKs50trimGST
starter issues
ok guys, i'm having major starter issues... I have a 98 GST. I picked up a starter from Jhaan Dude on friday and installed it tonight. When I first started it up, it made a grinding noise, then a second time it started right up, perfectly. I drove out to EP lanes and parked the car for about an hour or so. When I left and tried to start it nuthin would turn. All it would do is make a quiet like power up noise. Hard to explain, but nuthing turned over, it just made that noise when I turned the keys. I switched the starter because it was doing that same thing. I thought it was the starters bearing. Is the starters in 95-96's different from 97-99, because everything bolted right up and it started right away...at first. All help with this would be awesome because this is really pissing me off, i'm getting tired of push starting it.
BKs50trimGST is offline   Reply With Quote
Old 10-14-2007   #2
dragonforce
Re: starter issues
check all your connections. make sure they are clean and tight.
Old 10-14-2007   #3
BKs50trimGST
Post whore
Re: starter issues
I'll double check everything but why would it start right away, and then after just not do anything... its the same problem that i had before
Old 10-14-2007   #4
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Re: starter issues
rattle loose? pretty much anything can happen, its a dsm?
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 10-14-2007   #5
BKs50trimGST
Post whore
Re: starter issues
everything was tightened down to spec and stuff. Could it be something else that i'm overlooking? I had the car parked for about 3 months due to a dwi, I changed the alternator about 6 months ago. Could it maybe be the flywheel possibly?
Old 10-14-2007   #6
Hoffer00
Fight Man Champion! Cantankerous Tank Champion! Go Johnny Go Champion!
Send a message via Yahoo to Hoffer00
Re: starter issues
Have someone else try and start it. If it sounds like the starter is just spinning it is your flywheel.
Hoffer00 is offline   Reply With Quote
Old 10-15-2007   #7
BKs50trimGST
Post whore
Re: starter issues
ok lemme just try to play this out for whoever can help me with this. I have a 98 GST with a 91 6bolt motor. I used my old starter off of the 98 stock 7bolt motor. It worked fine and dandy. As of late as you know i've been having major problems. So I picked up a 95 Talon AWD starter from Jhaan_Dude. Would the 95 starter work on my set-up?
