Old 10-15-2007   #1
turbo install ??'s
So i am installing a new turbo that is oil cooled only.
From my research i have found that my options for the water lines are, 1. block the stock lines off some how (bolts/weld the outlets shut) or 2. pick up a NT water pipe, well i was at the J-yard and i found one, so i pulled it, but then i noticed the thermostat housing on the NT is different by way that is doesn't have a port for the coolant to feed the turbo, so i picked that up also.
Has anyone heard of doing this? Using the NT parts to install an oil cooled only turbo.
Also my external dumb is facing right at the front crossmember/subframe, is that gonna be safe? I think that i will get an extension welded onto it to clear the bottom of the car.
Any tips for denting the water pipe, i can't fit the compressor in there either.
I will post pics tomorrow.
Thanks
Aaron
