Old 11-02-2007   #1
GnArKiLl
GnArKiLl's Avatar
7bolt auto to 6bolt auto
my 93 talon has the stock 7bolt with auto tranny and i want to swap in a 6bolt and keep it auto.. what is needed to swap the motors and keep the 7bolt auto tranny?
Old 11-02-2007   #2
dragonforce
Re: 7bolt auto to 6bolt auto
i believe all you need is 6 bolt flex plate that t.conveter mounts. make sure you have the alignment bushing thing at the end of crankshaft. i'm not sure if 6 bolt and 7 bolt alignment bushings are the same.
Old 11-02-2007   #3
But why do you want to swap motors?
Old 11-02-2007   #4
GnArKiLl
GnArKiLl's Avatar
we have all the parts to build a 6bolt motor.. and im not to trusting of the 7bolt..
Old 11-03-2007   #5
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
7 bolt motors out of the 1993 don't issues with crank walk...
Its the motors from the 1995-1997 from the 2g that have the crank walk problem.
Its what you are using it for. If you are building a high hp car with built internals use 6 bolt, otherwise putting money and time into swapping seems pointless.
But thats just my 2 cents
Old 11-03-2007   #6
GnArKiLl
GnArKiLl's Avatar
well i think im gonna keep the 7bolt thats in it.. im putting eagle rods and weisco pistons in next week.. im gonna try to shoot for 500hp this spring. i guess if it goes ill swap a 6bolt then
Old 11-03-2007   #7
Andrew7dg
Andrew7dg's Avatar
Keep us updated on that, especially with an auto transmission.
I am thinking of taking a VR-4 galant and putting in an autotrans but wondered if the auto could take the hp and weight of the car.
Old 11-03-2007   #8
GnArKiLl
GnArKiLl's Avatar
i think it could hold up to the power and weight.. i think its importperformancetrans.com that makes some bullet proof parts for the autos
