Old 11-07-2007   #1
dedlewamp
Drives: 4G63
FS: 1990 Talon AWD Modded, Midwest
The time has come to sell my beloved 1990 Talon TSI AWD, as I will be moving soon and don’t have the space to really enjoy this car for awhile. There is over $17,000 invested in the car, with most of the receipts to show for it. This has the most desirable combo’s for any DSM, the four bolt rear and six bolt motor. You won’t have to worry about crankwalk on this motor, or too weak of a rear end during those 6000 RPM launches.
I am the third owner of this car. I purchased it from a gentlemen who bought it from an older gentleman with 161,019 miles. Everything was original including the engine, showing just how well this car was taken care of.
ENGINE/TURBO/POWER MODS AND UPGRADES TO THE 6-BOLT ENGINE: (Less than 10,000 miles on new engine)
- Forged Eagle Rods
- Forged Ross 8.5:1 pistons
- Clevite bearings
- ARP hardware all around(head studs, mains, and rod bolts)
- Mitsubishi MLS head gasket
- Precision Turbo Engineering 5031RE dual ball-bearing 50 trim turbocharger
- Forced Performance turbo inline oil filter fed from oil filter housing with restrictor
- Ported and Polished 1G cylinder head
o Forced Performance FP2 camshafts
o 1mm oversized valves
o Titanium springs and retainers
- Extreme Turbo Systems 10.5” race intercooler kit
- Greddy Type RS with recirculation kit
- TurboXS manual boost controller
- -Balance shafts removed
- New Mitsubishi front cover, knock sensor, O2 sensor, water pump, oil pump, hoses, and drive belts.
- New Mitsubishi timing belt and tensioner
o Installed when the new cylinder head was put on, less than 3,000 miles ago
EXHAUST
- Magnaflow 3” catback exhaust system
- Gutted high flow catalytic converter
- 3” downpipe
- Ported 2G exhaust manifold
INTAKE
- 2G MAS
- Custom 4” cold air intake
- K&N high flow air filter
- Dejon Tool 3” intake
SUSPENSION
- KYB GR2 shocks/struts
- Front/Rear anti-roll bars
BRAKES
- TurboTrix big brake upgrade
o Upgraded the tiny single piston calipers to larger dual piston calipers, larger slotted rotors in the front, as well as better pads, and stainless lines all around.
TRANSMISSION/DRIVELINE
- Shepherd Racing transmission
- Rebuilt transmission by John Shepherd. Transmission was fully rebuilt, replacing anything that needed to be replaced. Also installed was a 4-spyder differential using a brand new center differential from Mitsubishi
- 1992 shifter cables and shifter base
- Skate shifter bushings and solid transmission bracket
- ACT 2600lb clutch
- Raxles.com front axels
- Clutch assembly has been taken out and welded to remove any play in the pedal
- 4 bolt rear end
- New Mitsubishi master and slave cylinders
GAUGES
- Greddy EGT
- Autometer Boost
- AEM Wideband
IGNITION
- Accel 8mm plug wires
- NGK BR7ES spark plugs
FUEL
- 850cc Fuel Injector Clinic injectors
- Machined stock fuel rail
- Aeromotive fuel pressure regulator
- Walbro 255lph intake fuel pump with rewired main supply
- Stainless braided lines from fuel rail to filter and return
- Brand new Mitsubishi fuel filter
ETC
- DSMLink
- Fluidyne high performance all aluminum radiator
- Brand new Craftsman battery with warranty
o Relocated to rear of car
- Dual 12” electric fans, one puller, one pusher
- 1990 EPROM ECU
- Professionally tinted rear windows
- Pioneer CD head unit
- Upgraded front speakers
- Tons of other details(transfer case leak fix, carrier bearings fixed, gaskets, hoses, etc.)
Overall the car is in excellent condition. The car has never been smoked in, and always stored in a garage. Since I’ve owned it, it’s never seen snow. There is absolutely no rust on the body, and only minor surface rust on the undercarriage. Most of my time and money has gone into making the car fast and reliable, so I’ll list out possible issues with the car that the buyer may have.
- The paint. The car has the original paint. It looks great for a 17 year old paint job, but by no means is it perfect. The fenders are beginning to have some clear coat fade. The side panels are all straight, but have numerous parking lot dings. The hood appears to have been repainted, but not very well. With that being said, it still looks great, but it would be up to the buyer if it bothered them enough to paint it.
- Interior. The front interior is in excellent condition again for a 17 year old car. Seats are in perfect condition, carpet is clean, dash is good. The rear of the car has been gutted from the front seats back. I still have all of the plastic, carpet, and seats that can be included with the sale if requested.
- Air conditioning has been removed. Car retains power locks, power brakes, power steering, cruise control, heat, and power windows.
- Emissions. Car will not pass emissions in current state. Many emission controls in engine bay have been removed, along with missing catalytic converter.
Car is currently running at 20lbs of boost. It’s still relatively untuned, so there is a lot more potential in the car. A setup like this is capable of easily running 28+ lbs of boost and an 11 second timeslip. It starts right up just fine, runs cool, and even gets decent gas mileage if you stay out of boost. Always used Mobil 1 oil and filters every 2500 miles. New fluids in the transmission, transfer case, and rear end.
Of course, there is no warranty of any kind on the vehicle or any of the parts on the vehicle. I do certify that the odometer reading has never been tampered with by myself, and have a statement from the previous, original owner that he has never altered it either. The odometer still reads the total mileage that has been put on the car, not the new engine. I have put less than 7,000 miles on the car since I owned it, so many parts have even less miles on them. Also I will include a brand new set of tires for the stock rims FREE if we get a deal made in the next week or so. They are Eagle HP’s, in the stock size. Cost $400+There is no major mechanical issues that I know of. Car drives straight, no unusual sounds.
The car must be picked up, and PAID FOR WITH CASH OR A CERTIFIED BANK CHECK. I will not part out anything, as I just don’t have the time right now to remove parts and ship everything. Not looking for auto trades. Located in Iowa, zip code 50010. Please respond to this thread and PM if you are interested. I'll PM you my phone number if you'd like to talk, or even setup a time to come look at/drive the car.
With that being said, I’d like to get $6,500 or best offer for this. You’re getting a nice six bolt/four bolt 1G, $17,000 worth of after market and OEM goodies, and one of the best AWD platforms out there on a budget.
dedlewamp is offline   Reply With Quote
Old 11-07-2007   #2
dedlewamp
Drives: 4G63
Re: FS: 1990 Talon AWD Modded, Midwest
Old 11-07-2007   #3
Is this Daniel Halverson?
Old 11-08-2007   #4
dedlewamp
Drives: 4G63
Old 11-16-2007   #5
dedlewamp
Drives: 4G63
Price drop!
Old 11-24-2007   #6
Underhill
Any interest in trades? I have a 2000 Ducati 900ss with tons of extras.
Underhill is offline   Reply With Quote
Old 11-25-2007   #7
dedlewamp
Drives: 4G63
Sorry, not looking for anything with two wheels at the moment. Thanks though!
Old 12-09-2007   #8
TurboMeTroy
Send a message via MSN to TurboMeTroy
Where at in Iowa??
TurboMeTroy is offline   Reply With Quote
Old 12-09-2007   #9
dedlewamp
Drives: 4G63
Originally Posted by TurboMeTroy View Post
Where at in Iowa??
Ames, IA. Cyclone Land!! I had to after I saw your location :-)
Old 12-09-2007   #10
tim
tim's Avatar
Hawkeye land is better though, just so you know.
Old 12-28-2007   #11
93TalonES_NWS
93TalonES_NWS's Avatar
If this happens to be around in november of 08 ill be looking for a new dsm
93TalonES_NWS is offline   Reply With Quote
Old 12-28-2007   #12
dedlewamp
Drives: 4G63
I certainly hope it doesn't take that long to sell! I have a few people looking at it this weekend, but the car's still up for grabs!
Old 12-28-2007   #13
93TalonES_NWS
beautiful car. IF i had the cash i could take it off your hands
Old 01-02-2008   #14
streetTERROR
streetTERROR's Avatar
My buddy has an unmolested 91 stealth rt/tt he's looking to get into something smaller, but still awd/turbo. The only thing he has on it is a manual boost controller set to like 12psi, and a cd player, whoooo. He's just dumped new bearings in the bottom end professionally and has had a new drive axel custom made for it and I just replaced the rear inner bearing for him last week. New brakes and tires. Its like a Fireball red, with dark charcoal leather interior and all the power options you want including a moon roof. I don't think there are much miles on it. The only problem is the dumbass cut off his recirculation pipe with no supporting mods and put a bov on and now it dies off at stop signs lol. Its like a $10 tube, nbd. It's really nice, he had every ding professionally pulled out of it, but now a few months back a lady hit him in the rear bumper, no damage, just paint spider and a paint scuff on the corner of the bumper, he can probably have his step-dad (a bodyman) spotpaint it. He's wanting like $7500 for it but me and a couple of buddys all own eclipses and talons, so were trying to get him one. Im kinda doing this behind his back, but if your interested you might be able to get this for a trade.... possibly straight up, but I doubt it, maybe with a little money towards it, but I could coax him. Sorry for the novel, but just throwing it out there.
Nick Phelps
1993 Talon TSI AWD
streetTERROR is offline   Reply With Quote
Old 01-02-2008   #15
dedlewamp
Drives: 4G63
Hey, thanks for the offer, but unfortunately at the moment I am just looking for cash.
I'll post an update if something changes! Thanks!
Old 03-02-2008   #16
dedlewamp
Drives: 4G63
Still up for grabs, a few interested parties, but no $$$ yet.
Old 03-02-2008   #17
DSM_421
Sounds like a good set up and a great sleeper. Although you might want to drop the price a hair because the exterior is showing its age.
Old 03-02-2008   #18
dedlewamp
Drives: 4G63
It looks great for an 18 year old car, but I've spent all my money on making it fast and reliable. No rust on the body. I just don't have the time, or the space for this car right now. Taking offers!
Old 03-12-2008   #19
dedlewamp
Drives: 4G63
Bump, I'm moving soon so she needs to sell!
Old 03-14-2008   #20
Defiant
Any warranty parts?
Defiant is offline   Reply With Quote
