Old 11-21-2007   #1
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Bolts for engine
I need bolts to bolt the engine to the engine stand for a 4g64 but what kind of threads do they need?
Or if I am at the junk yard what bolts from the engine/transmission work?
I usually use bolts from the car rebuild but since all of those bolts are now back in my car I don't have any to use.
Old 11-21-2007   #2
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Re: Bolts for engine
Goto Ace Hardware, they're kinda expensive, but just keep them around. It'll cost ya like $20.
'04 Honda Ricer: stock
Old 11-21-2007   #3
I heard turbo bolts work.(never tried tho) They didnt have them by the ace by my house.
Old 11-21-2007   #4
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
I don't remember the size. It'ssomething like m10 standard pitch. Pull off the tranny and match one of the transmission bolts to some appropriate length ones at the hardware store.
Old 11-21-2007   #5
Yeah, the turbo bolts will work, they're a little short though.
Old 11-21-2007   #6
TwoTalons
Old & Grumpy
TwoTalons's Avatar
Drives: 1992 Eagle Talon TSi AWD
If you end up buying them, find a Fastenal store. Fraction of the cost compared to your local hardware store.
TwoTalons is offline   Reply With Quote
Old 11-21-2007   #7
The bolts you need: M10 x 1.25 x long enough to get 1/2" into the block.
Old 11-21-2007   #8
Andrew7dg
Andrew7dg's Avatar
Thats what I need!!! thank you
I went to Ace hardware also and Bought 4 bolts and even though they threaded a nut onto the transmission bolt and threaded the same nut onto another bolt, all 4 bolts wouldn't thread into the block correctly.
