Old 11-30-2007   #1
v8klla
v8klla's Avatar
Now Offering Zeitronix Widebands and Accessories! Many in stock!
What sets Zeitronix apart?
With their ZT2 wideband meter (included in each Zeitronix package) you can datalog AFR, Lambda, RPM, Vacuum, Boost, EGT, Throttle Position, and 0-5V Sensors. Choose either the LCD display or the ZR2 gauge and you can display AFR, boost, and EGT!
When you buy Zeitronix you're buying much more than just a wideband!
The LCD Display:
Yes, you can be fast without the A-pillar gauges. The remote LCD display gives you a stealth look and important data in high contrast digital format. The aluminum enclosure dimensions are 4.7" x 2" x 0.9" , slightly larger than the LCD display itself. The LCD fonts are bright white on a black background. High contrast LCD digits are visible even in a direct sunlight. A push of a button located on the right side of the LCD shows peak and hold maximum AFR, Lambda, EGT and Boost values. The LCD display communicates with the Zt-2 digitally through a serial interface. This allows for a clean display installation in the car, since all heavy wire connections are going to the Zt-2. The display serial cable is thin, black and easily blends with the dash. The new overlay is made from hard coated, scratch resistant material.
Click here for more info or to purchase the LCD bundle!
The ZR-1 Gauge:
-Stylish, machined, brushed finish aluminum bezel and slim enclosure giving the gauge an elegant appearance.
- High contrast LED display.
- Large 0.4" (10mm) digits.
- Slim design for flexible gauge mounting options.
- Programmable as AFR or Lambda gauge.
- Peak and Hold feature.
Click here for more info or to purchase the ZR-1 bundle!
The ZR-2 Gauge:
- One gauge for Wideband AFR, Lambda, Boost, Vacuum and EGT
- 16 gauge combinations
- 4 digits
- Stylish, machined, brushed finish aluminum bezel and slim enclosure gives the gauge an elegant appearance
- User programmable outer LED and inner numeric display values via a front push button
- English and Metric Units
- Large 0.3" (7.5mm) digits
- Slim, flat back, design for flexible gauge mounting options
Click here for more info or to purchase the ZR-2 Bundle!
Please PM us for special introductory pricing only from MAPerformance!
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
