Old 12-02-2007   #1
Madd_dips
Help?
Im not sure whether i need a new oil pump or whether i need a new balance shaft or new balancer sharft bearings? The oil light turn n after i drive the car for like 15-20 min. Before the light would only turn on at idle and as soon as i would rev it it would turn off. then it started flickering every once in a while. and now it just stays on after it seemslike the engine gets hot? Any suggestions?
Madd_dips is offline   Reply With Quote
Old 12-02-2007   #2
Re: Help?
What weight of oil are you running? I ran 5W-30 in a DSM once and the light would flicker at idle, switched back to 10W-30 the next day and it never happened again.
Old 12-02-2007   #3
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: Help?
i agree i would try that..
Old 12-02-2007   #4
twack
It was a auto get over it
twack's Avatar
Re: Help?
this happened to me and it turned out that the oil pressure sensor was falling off and a mess
Old 12-02-2007   #5
Re: Help?
+1, clean your oil sensor sender wire and make sure its on nice and snug. It's probably just that, nothing actually wrong.
Old 12-03-2007   #6
Re: Help?
check the sending unit. The best would be a aftermarket oil gauge
Old 12-03-2007   #7
twack
twack's Avatar
Re: Help?
Does anyone know the size of the sender, I have a aftermarket but its a different size and i need an adapter
