Old 12-11-2007   #1
Parts needed ASAP
I need these as soon as possible, so I can get my car running and back up to the twin cities.
1. Harness/wires for a 1g Cam Angle Sensor, it's rectangular and has four prongs I believe, it's the black one (hall effect) if that matters. I have the CAS itself, but nothing to plug it into on my 2g.
2. Banjo bolt and fitting to connect the turbo oil feed line on the head to my stainless line with (-4?) AN fitting (the $20 line from SBR). I originally bought the line to go to the filter housing, and it came with a banjo bolt that is a couple millimeters too wide to fit into the head.
Old 12-13-2007   #2
SBR_240sx
Send a message via AIM to SBR_240sx
Re: Parts needed ASAP
I dont know if this will help any but here are the part #'s that you need.
MF 650102 - This is the OEM banjo bolt. 12MM
Goodridge 776-04-M12P - This is the adaptor that tapers to the -4 AN line
SBR_240sx is offline   Reply With Quote
Old 12-13-2007   #3
Thanks, I just ended up ordering the SBR kit for the oil feed line kit from the head since I couldn't find just the bolt and fitting in time.
Old 12-13-2007   #4
User Name
Hates blue couplers.
User Name's Avatar
Drives: White 1Gb TSi
I found 3 last night in my box...But I'm so far away shipping would suck just for a bolt.
ForSale:
90 OFH+Cooler/AN fittings
FIC 850
FP Turbo kit
