Old 01-08-2008   #1
Minor clutch issue
I have a question about the way my clutch is acting. I think it just needs to be bled again, but I'll ask anyway.
After it's been sitting for a few days, the clutch will feel really soft and start grabbing just above the floor. After I drive through town it gets a bit stiffer and grabs higher up. After 15 miles of highway driving and not using the clutch it's still stiff too.
Then I let it sit for an hour and it's still stiff and grabs high up. But if I let it sit for another day or two it gets weak again.
I know it sounds like it needs to be bled, but I wouldn't expect it to stay pumped up for more than a few minutes without getting weak again.
Old 01-08-2008   #2
Re: Minor clutch issue
Thats strange. I'd start with bleeding it again and if that doesn't work check for a leaking master or slave cylinder.
Old 01-08-2008   #3
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Do what the kracka says.
Old 01-08-2008   #4
bleed it!
Old 01-08-2008   #5
Thats a 2G problem. The clutch needs to be properly adjusted.
Old 01-23-2008   #6
bouncer07
jack your car up, check the slave cylinder where the lines bolts to your bleeder. Check that line to see if its loose. Air can get in there and make your pedal stiff and soon your clutching will be off by alot making you slip. Stainless lines are the way to go!
bouncer07 is offline   Reply With Quote
