Old 01-18-2008   #1
HKSenilyks
Send a message via AIM to HKSenilyks
Newb question.
This doesn't have anything to do with dsm's, or turbos for that matter. But does anyone know why supercharged cars don't need Blow off valves?
I recently bought a supercharged Buick Park ave. and always wondered. Is it because as the t.b. butterfly closes as the supercharger slow down err....?
Thaught
HKSenilyks is offline   Reply With Quote
Old 01-18-2008   #2
User Name
Hates blue couplers.
User Name's Avatar
Drives: White 1Gb TSi
Re: Newb question.
A bov is made protect the compressor section of the turbo from damage due to pressure surges, not applicable on SC's.
The supercharger recycles the boosted air back into the intake, so as to minimize parasitic loss.
ForSale:
90 OFH+Cooler/AN fittings
FIC 850
FP Turbo kit
Old 01-19-2008   #3
Re: Newb question.
Superchargers are a little more robust, but the real reason is your car is an automatic. The engine doesn't immediately drop into vacuum from a boosted stated when you let off the gas on an auto. Buick GN's didn't have a BOV from the factory and they were turbocharged, and all were autos.
Old 01-25-2008   #4
HKSenilyks
Re: Newb question.
Yea I had a turbo sunbird that didn't come stock with a B.O.V. it was also an auto.
Thaught
Old 02-11-2008   #5
311evo
311evo's Avatar
Re: Newb question.
you can technically use one, but they wont do much unless ur running alot of boost. there kind of pointless as the main point of having a BOV is to save your turbo from compressor surge.
Old 02-11-2008   #6
Re: Newb question.
Depends on the application. Your car has roots blower and its located after the throttlebody.
A lot of the med-hi boost centrifugal kits these days (vortec) do inlcude bovs.
Old 02-11-2008   #7
Re: Newb question.
Yup, a lot of the supercharged S2000 guys are using BOV's.
Old 02-11-2008   #8
Re: Newb question.
actually i dont think even our dsms dont need a bov. I was actually thinking off blocking mine off when i go to the track, that way it holds a little more boost between shifts. (not sure if this will work or not on our cars) My buddy with the S15 Silvia (yes a real one) doesnt run a BOV when he goes to the track and hes on higher boost (17-20).
sure it wears the turbos compressor a little, but for how many times we change turbos, we arent going for longevity anyways.
Old 02-11-2008   #9
Re: Newb question.
I was going to say something, but this thread is retarded.
Old 02-11-2008   #10
Re: Newb question.
That made me chuckle
Old 02-26-2008   #11
RichardBBY
Re: Newb question.
I think this would be a bad idea. When you shut the throttle during shifts that air that is now pressureized and flowing through all of your pipes will have no where to go other then back towards the turbo. That rush of air back towards the turbo will cause the turbo to violently slow down, which is exactly the oppisite of what you said your trying to acomplish.
just my 2 cents.
RichardBBY is offline   Reply With Quote
Old 02-27-2008   #12
Re: Newb question.
Love it!!
It really has to do with location of the TB in relation to the supercharger or turbo. Close the TB on a supercharger and you immediately have vacuum on both side of it. And the supercharger speed is based directly on crank speed. Turbo chargers stay spooled longer and need a place to release the excess pressure between shifts to maintain high turbo shaft speeds. This helps reduce turbo lag between shifts and removes excess stress on the turbo.
Old 02-27-2008   #13
crazy_skier
A.E.K.Δ.B
crazy_skier's Avatar
Beer Dude 2 Champion!
Drives: 1994 Suburban
Re: Newb question.
just my 2 cents.
This is true, but at the track people are also shifting much quicker, or if using dsmlink there is nlts and then the throttle will not be closed at all. I have haerd of removing the bov for the track also though on high boost applications, since it does keep the pressure in the pipes and makes cars a little more responsive when shifting quickly. I would reccomend feathering off the throttle after crossing the mark for whatever distance your running so you dont cause huge compressor surge
Old 02-27-2008   #14
RichardBBY
Re: Newb question.
Your right, i could see how No Lift To Shift would make this a worth while modification for track use. He didn't mention using nlts. If anyone has ever driven a SRT4 with out any blow off valve, like they come from the factory, they have felt how badly that car falls on its face during the 1 - 2 shift. I would imagin the same problem would be felt if you were to unhook your bov. Unless of corse when you say high boost, you mean 25 to 30 pounds, in that case I would not know sence I personaly have never driven a car with that much boost.
theres a few more cents for ya!
