Old 01-24-2008   #1
COP Setups...
Found this via google search.
http://www.imwinning.com/copsetups.htm
Does this seem like a good deal? $250 +s&h
Old 01-24-2008   #2
Re: COP Setups...
Don't you also need a CDI box like a M&W ignition, so that they aren't actually worse than stock DSM stuff?
Old 01-24-2008   #3
Re: COP Setups...
Yes you do, and that ad doesn't say anything about having one.
Old 01-24-2008   #4
Re: COP Setups...
http://www.imwinning.com/instructionscop.htm looks like they dont seem to think you need a CDI box. also Buschur racing has a setup without a CDI box https://secure.buschurracing.com/cat...roducts_id=428
Old 01-24-2008   #5
Re: COP Setups...
None, use the stock ignition until you've maxed it out, and be thankful you don't have a weak-ass evo ignition!
Old 01-24-2008   #6
Re: COP Setups...
The reason i am even considering this is that currently i made a bracket that bolts to the block that holds my coil pack under the Magnus Intake manifold, and i feed the spark plug wires through the manifold and onto the plugs. The other day one of the spark plug wires came out of the coil packs and thus made my car run off 3 cylinders, i got it home and put it back on, but it made me realise that maybe i should look into a COP setup to clean things up.
Old 01-24-2008   #7
twack
It was a auto get over it
twack's Avatar
Re: COP Setups...
I just made my coil on plug setup for under 100
Old 01-25-2008   #8
Re: COP Setups...
Good job on believing everything you read on the internet.
Old 01-25-2008   #9
Re: COP Setups...
I never said i believed them, thats why i asked. It seems every COP setup i have seen whether it be on a average jo shmoe car or a setup for sale they dont say anything about the box.
Old 01-25-2008   #10
Re: COP Setups...
It depends. If you actually want to make it better than the stock system, then I would run a good CDI box though. Most people do it for looks and make 300hp, so any ignition would work.
Look at the cars on that site. Scary.
Old 01-25-2008   #11
twack
twack's Avatar
Re: COP Setups...
wow i just looked at those hack jobs they call rides.....wow
Old 01-25-2008   #12
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Re: COP Setups...
I got my coil on plug setup from a guy who makes them. It was 140-came with the connectors and everything pre-made. I then wired in a MSD dis-4 ignition box, and a plate it rests on on the driver's side back firewall. It's clean, and works. I have quite a few less mis-fires with it under boost, then I did before. I will see how it really holds up this summer, when I turn up the wick.
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 01-25-2008   #13
twack
twack's Avatar
Re: COP Setups...
How much can whp can they support before they need an ignition box
Old 01-25-2008   #14
Swifty1638
Swifty1638's Avatar
Re: COP Setups...
depends on the car, how good the coils are, etc etc..as shane said prolly 300-400ish.
-A. Swift
Black 1GB Mafia #1
I wanna go fast.
Old 01-25-2008   #15
Re: COP Setups...
I dunno what they can handle. I saw somewhere say 600. But you have to remember that the stock DSM ignition can handle over 700. People wire stock DSM ignition setups into Evos. We run a COP setup with an M&W box on that white Evo. Without it, it has major ignition problems.
Old 01-25-2008   #16
9guy9
Dumb and...........
Re: COP Setups...
If your looking for the stuff to make your own. I have 4 new 300m coils, and a polished alu plate I will sell. All thats missing are the connectors.
My car will be faster tomorrow.
9guy9 is offline   Reply With Quote
Old 01-26-2008   #17
2bar1g
Drives: .
Re: COP Setups...
COP on stock ecu ftl. Cop is fine when you have a standalone with 4 coil drivers, the one in the stock ecu gets burned up
2bar1g is offline   Reply With Quote
Old 02-10-2008   #18
jhaan_dude
jhaan_dude's Avatar
Art of War Champion! Yeti 1 Greece Champion! Mario Tetris 3 Champion!
Drives: a car
Re: COP Setups...
so the question is.....if you use a cop setup on a DSM just plug and play by itself, will you have ignition problems, like misfire and blowout???
Old 02-12-2008   #19
Jungy
Jungy's Avatar
Re: COP Setups...
Swifty1638 I'd look into relocating your dis-4 I've heard of alot of people having them go bad from the engine heat and elements getting to it.
Old 03-28-2008   #20
brando
Drives: gutlass
Re: COP Setups...
sorry to revive an old thread but i got a couple questions.
so with a COP setup do you need to run dsmlink or any aftermarket ecu ar can you use your stock ecu?
what all will you need? i was thinking of doing this but i just want to know all of what you'll need
