Old 01-28-2008   #1
green hornet
another 6 bolt swap Q
so i think i have every thing i am going to need, the one thing that i have been woundering about is if all the sensors on my motor will hook right up to my 2g. i know i need to do some cuting for the CAS but other than that every thing should hook up right!
FASTER AND FASTER! TILL THE FEAR OF DEATH IS OVER COME BY THE THRILL OF SPEED!!!
Old 01-28-2008   #2
Re: another 6 bolt swap Q
I was told to use all the 2g sensors on the 6 bolt motor.
2g TPS (has 4 pins vs 3), oil pressure, water temp sensors, knock sensor, etc.
The exception would be the 1g CAS which hooks up to the 2g plugs for crank/cams.
I'm not sure if any are the same between 1g and 2g, something like water temp or oil pressure may not have changed.
Old 01-28-2008   #3
They should all hook right up. The crank sensor won't be on the new engine, so keep that in mind. If you put DSMlink in, then no worries.
Old 01-28-2008   #4
dragonforce
I just finished mine. i used 1g head, 1g intake, and 1g oil pump assembly. i had to t-off vacuum lines for map sensor. used 90 cas and 1g TB. swapped the spark plug wires and injector wiring at ecu.
