Old 02-01-2008   #1
GnArKiLl
GnArKiLl's Avatar
bogging under boost
it started a few days ago when i get in the gas it will go just fine till it gets into boost then will just bog out.. i have tryed a few things but could use some help.. what should i check?
Old 02-01-2008   #2
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Re: bogging under boost
Well first off, what are your mods, car, etc??
Old 02-01-2008   #3
Ya, need more info on the car, and the "few things" you've already tried.
I'd check your plugs/wires first.
Old 02-01-2008   #4
Mod info would be nice. Just a couple things to check would be plugs/wires, and do a boost leak test.
Old 02-02-2008   #5
GnArKiLl
GnArKiLl's Avatar
will its an awd auto 14b, free mod done, mbc set to 14psi, mostly still stock... the car will run just fine untill it gets to about 2psi then bogs out but still builds boost just fine.. it just feels like its just not putting the power to the wheels.. i was thinking it might be the torque converter but the tranny still shifts just fine.
Old 02-02-2008   #6
sleepy2lazy
sleepy2lazy's Avatar
check plugs, wires as said earlier.
Also check spark plugs as it maybe goin bad as well.
sleepy2lazy is offline   Reply With Quote
Old 02-03-2008   #7
GnArKiLl
GnArKiLl's Avatar
well the plugs and wires and brand new and didnt to the trick..
Old 02-03-2008   #8
what did you gap the plugs to? Can you maybe explain more of what you mean by bogging? Is the car actually braking up and sounding like it's misfiring? Or does everything sound ok but it's just moving very slow? Do you have a logger or anyway to monitor your knock or timing retard?
Old 02-03-2008   #9
GnArKiLl
GnArKiLl's Avatar
plugs are at .30.. it doesnt sound like its brakeing up it just wont pick up speed when your in boost.. and i dont have a logger or anyway to monitor anything
Old 02-03-2008   #10
.030" gap is borderline. I would do a boost leak test right away, it is probably running rich under boost because of a leak.
Old 02-03-2008   #11
You really should look into getting some sort of logger. If you're knocking real bad, and pulling a bunch of timing, then that could be why you are losing all that power. Then you just need to figure out why.
Like Jet said, boost leak could be a big one. Also have you ever checked what your ignition timing is at?
Old 02-03-2008   #12
GnArKiLl
GnArKiLl's Avatar
we are goin to check the ignition timing today.. but the car doesnt bog as bad if i slowly get on the gas so i was thinkin boost leak
Old 02-04-2008   #13
GnArKiLl
GnArKiLl's Avatar
also if i get on and off the gas it will go away more and more each time
Old 02-04-2008   #14
Go do a boost leak test, and check ignition timing. Then report back.
Old 02-04-2008   #15
GnArKiLl
GnArKiLl's Avatar
ok well no boost leaks.. and timing is good.. but i did pull the intercooler and it had some oil in it so i swaped intercoolers. after checking a few things it had gotten alittle better but its still not gone.
Old 02-04-2008   #16
What was the ignition timing at? Did you make sure and ground the timing plug when you checked it?
Old 02-04-2008   #17
GnArKiLl
GnArKiLl's Avatar
ok well after putting bigger exhaust on it the problem seems to have gone away. but ill know more by tomorrow
Old 02-05-2008   #18
Bueler?
