Old 02-10-2008   #1
TCSpence
Idle/Driveability issue
A recent issue has popped up with my Talon. Here are the symptoms.
Upon startup, idle is ~1k, idles fine for 5 seconds, and dies. I restart it and it holds for a few seconds, and dies. When I pedal it to keep it running and its warmed up, it has a hard time revving past ~4k. It gets to 4k, hesitates and stutters for a few seconds, and moves on slowly. I have my ISC, EGR, FIAV blocked and unhooked, which I believe is causing me to throw check engine lights. Can anybody shed any light on the situation?? Could it be ECU related? Timing? I checked all my charge/vacuum pipes and everything seems ok.
Mods are: 16g, 255lph fuel pump, 550cc injectors
Brand new head gasket, studs, all gaskets, clutch, etc.
Thanks
TCSpence is offline   Reply With Quote
