Old 02-22-2008   #1
AVCR not controlling boost...
Hey guys,
I was wondering if any of you have installed an AVCR with an External Wastegate before?
For some reason the AVCR i have isnt controlling boost at all. I have it set at 1bar and 70% duty across the line. but when i boost, it just continues to go higher. Even the avcr shows a peak much higher.
In the manual it states that if you have an internal wg you need to hook up the NO port and the COM port, the NO port goes to the Pressure source, and the COM goes to the WG. But if you have an external WG, then you need to hook the other port to the top of the WG. I didnt do that last part. Do we actually need that or can it be left empty and i should be looking at other problems?
Thanks in advance.
Tom
