Old 03-06-2008   #1
4seasons69
4seasons69's Avatar
t04b v-trim question
I have a 1990 talon tsi awd. I just got a bullseye power t04b v-trim. I know I need an ss oil feed line. I'm wondering if anyone knows if the stock oil return line will work or if I need to get an ss return line as well. thanks
Old 03-06-2008   #2
iceminion
iceminion's Avatar
Re: t04b v-trim question
will the stock banjo bolt oil feed line work? I do not believe so.
Just buy the SS line.
Make sure to attach the SS line to the oil filter housing, you will get greater oil pressure to the turbo, which is better. (i think)
building a 3000GT AWD Turbo.
Old 03-06-2008   #3
Just an FYI, those turbos are junk. I'd encourage you to read some of the stories of those POS's on Toonerz. Mike Huml from Slowboy even classified them as low quality or something of that nature.
Old 03-06-2008   #4
4seasons69
4seasons69's Avatar
I know the oil feed line won't work and I'm getting an ss one. I was asking about the oil return line. If that would work
Old 03-06-2008   #5
4seasons69
4seasons69's Avatar
I've done some research and haven't really found much bad info about them. I brought it into MAPerformace and had them look it over and they said if your getting a good deal on it's a deacent turbo. also from what I've found on dsmtuners it's a garret turbo with bullseye's turbine housing. I could be wrong but that is just what I found so I dunno
Old 03-06-2008   #6
iceminion
iceminion's Avatar
+1 on it being a good turbo, we have beaten the shit out of ours, turned the car off with the turbo glowing, no leaks, shaft play or problems. Pulls like a son-of-a-bitch.
the only criticism is the compressor housing leaked, needed to use a thin layer of rtv to stop it....aside from that the turbo is fine
Old 03-06-2008   #7
iceminion
iceminion's Avatar
in response to "its a bad turbo" - think about it, it has 2 moving parts: the turbine and the wastegate.
lets rule out the wastegate because it is so simple.
that leaves the turbine:
balance it
use good bearings
use good seals
unless I am mistaken that is it, it is a simple machine, not many parts to fail.
now a ford, you could call that a piece of shit, lost and lots of parts to fail, even when working properly those cars are pieces of shit.
Old 03-06-2008   #8
4seasons69
4seasons69's Avatar
back to my question will the stock oil return line work?
Old 03-06-2008   #9
allyoucaneat_talon
allyoucaneat_talon's Avatar
Drives: 93 Talon Tsi AWD
Is there a different between the v- trim and the m-trim, cause yea i have a to4b m-trim and I'm about to put the turbo in my car, i have a 92 gsx. Sorry for writing in here 4season69, but yea when i bought my turbo it came with the ss oil line and ss return line, so i don't know if the stock one will fit. I think you might want the ss oil return line, cause it bigger than your stock one. Just a thought. Yea i have read up on these turbo and i heard their really good. Their High flow turbo not high boost turbo. So maybe with 15 psi you may get alot of power already but depending on your set up and what you use to tune with.
95 Talon Tsi= SOLD
92 Mitsu Gsx= SOLD
Old 03-06-2008   #10
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Too much oil pressure= blowing oil past turbo seals. You won't have too much pressure from the filter housing on a journal bearing, but ball bearing you need to feed it off the head (less pressure)
Old 03-06-2008   #11
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
No the stock line will not work. Get a SS push lock from MAP or somethin.
Old 03-06-2008   #12
4seasons69
4seasons69's Avatar
thanks for the help. i'll pick up an ss line
