Old 03-09-2008   #1
bartgerbracht
master cylinder
I only have about a inch of pedal right at the floor with my act 2600, I have the steel braided clutch line and a extended slave rod. does the second gen master cylinder have more volume of flow.
bartgerbracht is offline   Reply With Quote
Old 03-09-2008   #2
dragonforce
Re: master cylinder
try adjusting the clutch master cylinder rod.
Old 03-09-2008   #3
Re: master cylinder
Bleed the system yet?
Old 03-10-2008   #4
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: master cylinder
Same thing with mine,
I didn't buy the extended rod (my rod is long enough),
Go underneath the dash and look where the clutch petal is attached to the master cylinder. (under the dash looking up it is inbetween the break and gas petal I think, push the clutch and you will find it) loosen the nut, spin the rod with your hand and tighten the nut back up.
Old 03-10-2008   #5
Re: master cylinder
I personally, have NEVER had any engagement problems in any of the 4 AWD 5spd DSMs I've ever owned. I've had ACT2600s in each one, some with stock flywheels and aftermakert ones (ACT, Fidanza).
Old 03-10-2008   #6
crazy_skier
A.E.K.Δ.B
crazy_skier's Avatar
Beer Dude 2 Champion!
Drives: 1994 Suburban
Re: master cylinder
try adjusting your master cylinder, and then check both the master and slave for ANY leaking oil after bleeding the system if the adjustment doesnt work. Otherwise I would drop the tranny and see if the clutch fork is bent, the extended rod will only hid a problem in the system which will get worse over time.
