Old 03-24-2008   #1
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
CHEAP parts!!! Take them away!
I have so many parts that I just NEED to get rid of! They are taking up too much space and I need the money. Please help me out and take these off my hands. If you don't like the price, offer me somthing else. I also have lots of pictures of this stuff so just ask and I will send them to you. Thanks!
First off are 1g parts. They came off my 91 talon this winter with only 64k on them.
1g parts
Stock fwd muffler – $20
Heat shields – upper and lower - $10
Stock fuel pump – $35
Condenser fan – $15
Stock intake filter – good shape - $10
Stock intake filter canister - $5
a/c compressor – worked perfect - $45
a/c compressor bracket - $20
a/c misc. lines - $5
a/c fuse/relay box - $15
ecu – non eprom – needs rebuild - SOLD
CAS – SOLD
O2 housing – $20
Power steering pump - $45
Power steering bracket - $10
Driver side motor mount bracket - $20
Cruise control assembly - $25
Washer fluid container - $20
Side mount intercooler - $30
Exhaust manifold - $30
stock intake tube - $10
battery trey bracket - $5
clutch fluid line bracket - $5
power steering canister - $20
charcoal canister - $5
maf with K&N filter – lower honey comb removed - $50
coil springs – very good shape - $80
pressure plate - $20
flywheel - $25
camshafts with or without gears- $65
hood with some small chips - $100
under hood heat shield - $25
Next are 2g parts, mileage varies with these but they're all in good condition.
2g parts
Stock UICP with BOV - $15
Stock intake tube - $10
Stock intake box with filter - $10
a/c compressor bracket - $30
crank pulley - $30
power steering pump - $45
thermostat housing – with sensors and cap - $35
o2 housing - $30
belt tensioner bracket - $15
lower intercooler pipe silencer thing - $5
driver side motor mount and bolt - $25
Then I have some misc parts here.
misc parts
2 tps’s - $15 for one
Accel 8mm spark plug wires - SOLD
2 9.3mm spark plug wires - $10
Oil cap - $5
-1990 Mitsubishi Cyborg 4WD-
