Old 03-25-2008   #1
green hornet
1g to 2g motor wire harness HELP
i was looking at the harness on the car and the sensor plugs on my motor and noticed that all the plugs on the motor are rectangle or square, and a couple of the ones on my car are triangle, it seemse that this is going to cause a problem, eny one have eny tips, the motor is out of a 1990 eclipse gst, and is going into a 95 gst.
this is my first swap so bear with me here.
also eny one know where i can get a pic of a 2g wiring harness that is labled on what goes where.
FASTER AND FASTER! TILL THE FEAR OF DEATH IS OVER COME BY THE THRILL OF SPEED!!!
Old 03-25-2008   #2
Re: 1g to 2g motor wire harness HELP
One triangle on the very end by itself is for the AC. The triangle next to a square a few inches from the end is crank/cam sensor as I said earlier, the triangle a few inches further back, near the center of the intake manifold is for the coil pack. Everything pretty much falls into place really, I was worried about it until I got the motor in and everything was really simple to figure out.
According to magnus writeup you should be using the 2g sensor for TPS, the 1g is different. Not sure if the other sensors matter much.
