Go Back   MitsuStyle > The Homefront! > The Parking Lot - On & Off Topic > Video Forum
Old 03-26-2008   #1
Aquamist HFS-1, GM BCS, and Tephra v5: together at last!
Like ebony and ivory, I have my Aquamist HFS-1, GM BCS, and tephra v5 working in perfect harmony on my car. Boost is semi-dialed in so that my base map hovers around 21psi and my alt map hovers around 26psi. Base map is a basic pump gas tune I put together for myself, and the alt map is a modified version of my tune from my SMC alky kit. Both need refinement, but you get the idea of how awesome these technologies working together is!
I donated money to Tephra, did you?
There is no fancy footwork here, there are no extra switches. I have a 240k resistor running from a 12v source in the dds junction box that is switched on and off using the dds and then runs to pin 42 of my ecu. Simply turn dds off and you drop down to a standard pump gas tune. If any of the standard failsafe catches on the aquamist kit are hit, it falls back to the pump gas tune (and low boost) as well.
Old 03-26-2008   #2
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Re: Aquamist HFS-1, GM BCS, and Tephra v5: together at last!
For some reason i thought i read that the tephra v5 was not out yet for the 05 model years?
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 03-26-2008   #3
He is not using a USDM ROM any longer, for this to work he had to switch to the Euro one.
Old 03-26-2008   #4
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
oh ok, that makes sense. That is really cool though.
-Matt
'06 Acura TL
Old 03-26-2008   #5
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
im jealous! So how much was the whole kit? Are prices comparable to doing an e85 conversion?
pics or gtfo
Old 03-26-2008   #6
I really have no idea, I suppose it would be about the same, yes. You could use tephra v5 to make your car semi-flex fuel, have a pump gas map and an E85 map
Old 03-26-2008   #7
Damn you Evo's and your fancy ECU's!
Old 03-27-2008   #8
Thats sweet!
