Old 04-02-2008   #1
Spyder Project 2008
Everyone else is making project thread so I thought Id start a new one.
This is my old thread for people that dont know what I have done.
http://www.mitsustyle.com/forums/showthread.php?t=14001
My cars current condition is BROKEN
Last fall my car made a loud noise on the dyno and Shane thinks its the flywheel bolts coming loose.
In the next few weeks I will be taking it out of the garage and taking the tranny off and replacing the flywheel bolts, assuming thats what I find to be wrong. I purchased a flywheel spacer out of an auto from mitsu, and a set of ARP flywheel bolts.When the trans is out Im going to paint it so it wont look so ugly. That is all Im planning right now just incase something big went wrong.
Here is a pic of my car as its been since the fall.
My Sisters garage. 3 car garage, 3rd stall is extra deep and about 2 storys tall. I wish it was mine!
I will keep updating as parts come in and the car gets fixed.
1998 Spyder AWD
567hp
490tq
Old 04-02-2008   #2
Re: Spyder Project 2008
Let's fix it now!!!!!!!!!!!!!
Old 04-02-2008   #3
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
You can bring that tranny over and blast it at my house if ya want.
Amsoil Dealer
Old 04-02-2008   #4
He needs too, its really the only ugly thing under his hood.
Old 04-02-2008   #5
And the water neck area!
1998 Spyder AWD
567hp
490tq
Old 04-03-2008   #6
mike55112
mike55112's Avatar
Drives: 04 evo
fix it, I dont work this weekend and its going to be so nice!!! I dont care if you have to work cause you need to grow some balls and call in sick for the first time.
Old 04-03-2008   #7
Im not doing it this weekend. I have to work and I havent even asked my sister is its cool if I work on it at her house.
1998 Spyder AWD
567hp
490tq
Old 04-19-2008   #8
95talonracer
Finally Tuned...
Drives: Spyder GSX
Have you made any progress?
Amsoil Dealer
Old 04-19-2008   #9
No I have not. Will be in the next few weeks. I never get any time off of work to work on it.
1998 Spyder AWD
567hp
490tq
Old 04-19-2008   #10
Take time off...
Old 04-19-2008   #11
Its not that easy...
BUT I got a new FMIC the other day along with some other parts on the way.
1998 Spyder AWD
567hp
490tq
Old 04-19-2008   #12
your thread doesnt have enough pics. isnt your car non-turbo right now? 4g64 FTL.
Old 04-19-2008   #13
Yes, I actually took out the original non turbo 2.4 and fabricated in a 420A. Its pretty bad ass
1998 Spyder AWD
567hp
490tq
Old 04-19-2008   #14
I'm transplanting a Geo 3-cylinder into mine. I've heard good things.
Old 04-19-2008   #15
Well I got a good deal on the 420A. It already has worn rings and they said they had a custom valve job done, I believe they called it a bent valve job. pretty badass IMO!
1998 Spyder AWD
567hp
490tq
Old 04-19-2008   #16
wants to be sideways...
123abc's Avatar
Drives: Loud cars
I've actually been looking into swapping an NSX v6 into my Laser just so I can have Vtec and 2 extra cylinders.
Shouldn't be hard, custom axles, wiring, new mounts, etc.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 04-20-2008   #17
95talonracer
Finally Tuned...
Drives: Spyder GSX
I am taking out my motor and putting in an avenger motor because it has more cylinders and that means more power.
Amsoil Dealer
Old 04-28-2008   #18
Alright here is my update:
Today I went to work on my car. I got the upper and lower IC pipes, intake, starter and slave cylinder out. I reached in the starter hole and wiggled the flywheel and its loose. So the good news is its probably just the Flywheel!!!
There is a big puddle under my car of oil. Looked around under the car and the oil return was leaking. The AN fitting came loose, and also my wastegate dump was loose. I dont know whats going on with my car but everything is loose .
Anyways, I got a few new parts. Here are some pics...
SSAC FMIC, Accell wire, FP3575, FP manifold, Greddy cam gears, Clear timing cover, and some Tein Flex Coilovers.
Im going to get the FP manifold coated and cleaned so it will look brand new. Thats all I have for now.
1998 Spyder AWD
567hp
490tq
Old 05-05-2008   #19
Alright, Here is the update that people are waiting for...
The flywheel was loose.
Why?
Well 2 bolts broke and 2 were loose.
Why?
On the crankshaft there is a piece in the middle for automatic cars, Well noone told me I have never even heard about this til today. So I left it in thinking it was part of the crankshaft. So the flywheel wasnt even seated on the crankshaft. So it acted like a spacer, and that is what snapped the bolts. Notice in the pics below the bolt have a section that looks nice, that was sitting inbetween the cank and the flywheel. the flywheel looked damaged but it was just chunks of the "ring" on the flywheel. Ground it down and now its all good!
I got the broken off bolt out! THANK GOD!!! So now all I have to do is get that "ring' out of the crankshaft and its all good.
Thank you to Chris and Kyle at MAP for helping me with my problem! I was all pissed until they told me I didnt need that "ring" on the crankshaft!
1998 Spyder AWD
567hp
490tq
Old 05-05-2008   #20
What I saw when I took the clutch off
The "Ring" and 2 broken bolts
My nice flywheel bolts
Before grinding
After grinding
1998 Spyder AWD
567hp
490tq
