Old 04-04-2008   #1
Capinoy123
Capinoy123's Avatar
Drives: A paint faded Red/pink/black 90 eclipse. Collector Plates!
Balance shaft removal question?
Im going to remove my balance shafts pretty soon here. Just wondering what kind of machine work or balancing you would consider? I have wiesco pistons and eagle rods on a stock crank. would i just balance the crank or what?
Best E.T 10.5 @ 137 on 30 psi, E-85 and street tires! (never dyno'd)
Capinoy123 is offline   Reply With Quote
Old 04-04-2008   #2
Re: Balance shaft removal question?
Balance shafts do not require internal engine balance but it helps.
I recommend balancing the full engine rotating assembly if you are building the engine ,otherwise if leaving the motor in the car ,yank them both ,toss in a full cut down shaft or mirage stub shaft and let it buck.
Old 04-04-2008   #3
What happened to all the turned down shafts that LSE used to have?
