Old 04-13-2008   #1
RichardBBY
setting timing on 91 laser
so my buddy is putting a timing belt onto a 91 laser with the 2.0 turbo motor.
can someone give me a quick walk through for setting the timing of the cams?
RichardBBY is offline   Reply With Quote
Old 04-13-2008   #2
Re: setting timing on 91 laser
There's a mark on each of the cam gears. Make sure they're lined up pointing toward eachother. put the belt on, then rotate the engine by hand and make sure everything still lines up.
Old 04-13-2008   #3
RichardBBY
thanks man, i figured there were going to be marks, just wernt sure what to line them up with.
correct me if im wrong, but the engine should be at TDC on the number 1 cylinder correct?
Old 04-13-2008   #4
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
http://www.vfaq.com/index-main.html this has step bye step. Click on engine and scroll down.
Old 04-13-2008   #5
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Make sure the dowels on the cam gears are pointing up when you line the marks up. Line up the oil pump marks and the timing marks. Pretty simple really. The only hard part (for me anyway) is getting the tensioner gap right, but I think as long as you're ballpark you're probably just fine.
